Will these F-type wheels be plug and play?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by larryt1026, Jul 29, 2013.
  1. larryt1026
    larryt1026 Junior Member
    61
    Big fan of the below wheels. Plug and play? Thanks!
  2. JANSone
    JANSone JANS one
    87
    OC, CA
    according to the auction descriptions i have read, they were "designed to work with the OEM tire size" which probably means they are plug and play as you say
  3. mellowjd
    mellowjd Junior Member
    43
    I've come really close to ordering these up.. it seems to be a great deal on some good looking wheels. The offsets are different on these at 36mm I believe compared to 45mm on the TRD plus wheels.
  4. larryt1026
    61
    Lol right? They sure are a great price. Will the offset require additional adjustments you think?
  5. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    That should be fine. The wheel will poke out a bit farther, but shouldn't hit the wheel well or anything like that.
  6. larryt1026
    61
    here are exact specs. so no rubbing? I will not be lowering.
    • Size: 17 x 7
    • Bolt Pattern: 5-100
    • Offset: 36mm
    • Weight 28.65 lbs
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    29 lbs! :eek:
    Wow, that's really chubby.
    SCH-I535
  8. mellowjd
    43
    I just ordered a set from Lexussandiego and used my ebay mobile 10% off coupon making it a pretty sweet deal. From what I have read the 29 lb. figure is not accurate and these are actually weighing at 22 lbs. I will know for sure when they arrive and can update you here.
  9. larryt1026
    61
    yea man that would be great! let me know if its a direct fit. would rather not run and hubcentric rings or spacers.
  10. larryt1026
    61
    Any luck with these wheels?! I am excited to see them on a Prius
  11. mellowjd
    43
    Yes I am happy them so far and didn't have any issues with fitment. They weighed in at 22.6 lbs on our household scale. I wanted a good looking Toyota wheel and the price was right. I will add some pics soon... Will have to get a good car wash first. I'm thinking these wheels will look really good with the semi-chrome lower door mouldings...
  12. larryt1026
    61
    any pics yet? so excited to see them on your car!
  13. mellowjd
    43
    I took some cell phone shots and they didn't turn out too good.. going to have to use the DSLR. Thanks for reminding me I'll get something up very soon.
  14. jpsdrivesfast
    jpsdrivesfast Junior Member
    Austin, TX
    I'm excited to see how they look and also do you notice any MPG difference?? What kind of tires did you put on them?
  15. bigdaddeywalt
    bigdaddeywalt Junior Member
    there is someone who posted a picture of his prius with those wheels on it, I believe its in the post ur wheels topic
  16. bigdaddeywalt
    sorry mellowjd, it was your car :)
  17. mellowjd
    43
