Will these wheels fit a Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by JC91006, Apr 8, 2014.
  1. JC91006
    16,828
    8,601
    I saw some WRX 18" wheels and I thought they looked great. Does anyone know if they fit the Prius?
    Offset: +55
    Bolt pattern: 5x114
  2. j-werkz
    j-werkz Junior Member
    17
    Los Angeles
    Bolt pattern should be 5x100
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Bolt pattern would fit my Camry. ;)
    +55 offset might stick out and rub the fenders on the Prius too. I think +45/48 is about as far as you want to go.
    SCH-I535
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    5x114 is right for Prius v
  5. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    +55 mm offset is farther into the wheel well and would need a spacer to bring out to flush fit. I've found that +42 mm offset is just about spot on for flush wheel fitment... +40 sticks outside the front wheel well fender line a tad.
