Will these wheels fit on a 2015 Prius Plugin?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by sumting77, Aug 25, 2021.
Tags:
  1. sumting77
    sumting77 Junior Member
    22
    So Cal
    2015 Prius Plug-in
    Just purchased a 2015 Prius Plugin and the wheels and tires need replacement. Prior owner replaced these with (what he said) where OEM Forged wheels and removed TPMS sensors. TPMS Sensor Light is on along with Traction Control light. I suspect this may have to do with the wheel replacement.
    I am hoping OEM wheels and adding TPMS sensors will resolve this. I am also looking for a more OEM look but confused with the different sizing on wheels and tires. Would the ones below fit? Any help is appreciated.
    Option A (They come from a 2019 Prius Prime)
    15x6.5 oem Toyota Prius wheels. Comes with 195 65 15 Toyo tires
    Option B
    OEM Wheels/Tires from a 2014 Prius
    #1 sumting77, Aug 25, 2021
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The lug pattern is 5 x 100.
  3. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    You can pretty much put any Gen 2 through 4 Prius hatchback OEM wheel on your Prime.
    The only exceptions are the Prius c and the Prius v. They have different bolt patterns.
    Additionally, you can put aftermarket or OEM wheels from other manufacturers/models as long as they have a 5x100 bolt pattern and an offset between +40-55 or thereabouts.
    Here's our 2011 Prius on Subaru wheels with the OEM TPMS sensors moved over. 16 x 6.5 rims, 5x100 bolt pattern and +55mm offset.
    And our 2014 Corolla on aftermarket Enkei wheels with the OEM TPMS sensors moved to the wheels, 16 x 7, 5x100 bolt pattern, and +40mm offset.
    Note: the wheels would be interchangeable between our two cars as far as fitment.
    #3 xliderider, Aug 25, 2021
    privilege likes this.
  4. xliderider
    8,140
    3,278
    Honolulu, HI
  5. sumting77
    22
    So Cal
    2015 Prius Plug-in
    Thank you all for your replies!
    iPhone ?
  6. privilege
    privilege Active Member
    659
    169
    Birmingham
    the oem forged wheels are very light, very high quality.
    AFTERMARKET wheels are generally not forged , but similarly priced and heavier.
    aftermarket forged are extremely expensive.
    if you don't mind the extra weight and lost economy, you can pick up some Subaru brz/frs wheels fairly cheap and they look much much better, but cost in fuel economy and require 3mm spacers to fit.
  7. Mendel Leisk
    42,263
    If you can score a set of the original PIP rims that’d be my vote. They’re a nice looking rim.
  8. xliderider
    8,140
    3,278
    Honolulu, HI
    FYI, regarding the 3mm spacers referred to above to fit BRZ/FRS/FT86 wheels. The thin spacers are only necessary on the rear wheels of the Prius, or the spokes make contact with the brake caliper holders. The Subaru wheels I put on the Prius clear the rear caliper holders by only about 1 or 1.5 mm, a little close for comfort, so I put a set of 3mm spacers on for peace of mind.
    I didn't include the weights of the wheels shown in my post above, but weight was very much a concern when considering what to put on the cars.
    The Enkei wheels are 16.9 lbs on our digital bathroom scale. The OEM steelies from the Corolla are 20.9 lbs on the same scale.
    The 16 inch Subaru wheels are 16.7 lbs on the scale. The 15 inch OEM Prius alloy wheels are 15.7 lbs on the scale. I think one pound heavier for a +1 wheel size is pretty good.
    I noticed an immediate difference in acceleration using my "butt dyno", on the Corolla. The 4 lb difference per wheel was noticeable.
    As far as the Prius though, it wasn't really noticeable. Time will tell, as I do monitor mpg on our cars on Fuelly.
    The Camry SE 17 inch wheels (not compatible with the Prius) are anchors at 25 lbs each on the bathroom scale.
    #8 xliderider, Aug 27, 2021
    privilege and Mendel Leisk like this.
  9. Mendel Leisk
    42,263
    3rd gen Prius 17" rims are only about a pound less, for another data point.
    Are those 15" or 16" (if you know)? I have some older Corrolla 15" steel rims, and I've got a vague recollection they're around 16 pounds. Likely based on weighing a complete tire/rim assembly, then deducting the tire weight, which is not an exact process, especially with some tread wear.
  10. xliderider
    8,140
    3,278
    Honolulu, HI
    The OEM steelies from our Corolla are 16s.
    The 3rd Gen 17s are a bit "chubby". I had a set of Subaru Legacy GT wheels of similar design that were a shade under 21 lbs on the scale. The spokes were slimmer.
    Picture is through Search, I deleted my pictures of the wheels when I sold them. Screenshot_20210827-081214_Chrome.jpeg
  11. privilege
    659
    169
    Birmingham
    on my 2011 the inner spokes if the frs/brz rubbed the front and rear calipers.
    that's cool too know the weights of all the wheels you listed. thanks !
    xliderider likes this.
