Will this setup work?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Danger, Feb 24, 2018.
  1. Danger
    Danger Member
    175
    22
    Frisco
    I have been doing my research and I just want a decent audio system. My car is equipped with a JBL amp. My setup would consist of replacing the front and rear speakers. Fronts would be components and rears would be something better than stock. I would then be getting the audiocontrol LC7i and the NVX MVPA4 micro amp. This pretty much bypasses the JBL amp. Will there be any issues such as navi or BT audio? I was thinking to cut the speaker wires prior to them going into the JBL amp. Wire speaker wires into the LC7i and connect the rca cables to the NVX. Cut the output speaker wires from the jbl amp and wire those into the NVX output. If this works what can I do to add a small sub in the future? Should I just get a 5 channel amp instead?
  2. frodoz737
    frodoz737 Top Wrench
    4,721
    2,517
    33
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    If you plan on to resell the car then keep all the old stuff splice cables carefully. You can use the existing HU's high level outs and wire it into the amp if the amp has high level inputs. Good idea on a 5-channel amp because you can get one with a dedicated subout and not buy a dedicated sub amp, thats if you ain't push a 15" sub. Bluetooth and navigation won't be affected unless you decide to go with another HU that doesn't have compatible connectors or accommodate likewise features.
  4. Danger
    Danger Member
    175
    22
    Frisco
    I know my system won't be a 1k system but want something better than just replacing speakers. I want a clean easy system.
