Will this void my warranty?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Peaquod, Dec 2, 2008.
  1. Peaquod
    Peaquod New Member
    Ann Arbor, MI
    I recently blew the main 100A DC/DC fusible link (long story), but have confirmed no further damage by temporarily bridging the gap in the shot fuse with an alligator clip.
    I'm driving it straight to the dealer tomorrow morning to have the fusible link assembly replaced. Question: If I drive right into their service bay, pop the hood and pull my clip out, are they likely to threaten any part of the warranty?
    Thanks!
  2. jgod12
    jgod12 Junior Member
    33
    Hanover, PA
    Please tell us how you blew this fusible link? I don't mind a long story plus I think driving into the dealer they are going to want to know the same. Just curious:)
  3. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Your service will be recorded by the Toyota dealer. If something on this circuit fails in the future your warranty may be denied. It won't effect other unrelated potential warranty claims.
    I'm also curious how you popped the fusable link. Unless you solved the problem before you jumped the circuit with the alligator clips you may have damaged something else further into the circuit. The link popped for a reason it needs to be fixed.
  4. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    if you damage something on the way, you're definitely on the hook for it. if it were us (DH being a former prius tech) we would call a tow truck. as far as future inverter problems, this would give them ammo to deny you warranty coverage.
  5. Peaquod
    Peaquod New Member
    Ann Arbor, MI
  6. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Dealers don't just record service visits that could void warranties they record all of them. This can be very helpful if you are buying a used car and want to know if the required maintenance has been done.
  7. butchbs1985
    butchbs1985 Taking things apart is fun!
    229
    16
    ChicagoLand
    2013 Prius v wagon
    Why not rig up a temporary 100A fuse instead of using an alligator clip? That way, the circuit is still protected and they can't say that you had bypassed the protection provided by the fuse.
    BTW, from a EE background, DON'T BYPASS FUSES UNDER ANY CIRCUMSTANCES!!! THEY ARE THERE FOR A REASON:confused:
  8. Peaquod
    Peaquod New Member
    Ann Arbor, MI
    The alligator clip only bridged the gap in the fuse, so most of the fuse arm was still intact - another section of the fuse would blow if need be. Anyway, I only kept the clip on there long enough to back it out of the garage and turn it around for the tow truck :)
  9. richard schumacher
    7,663
    1,038
    United States
    Probably OK if you don't post anything about it in a public forum :_>
  10. tochatihu
    tochatihu Senior Member
    9,058
    3,529
    Kunming Yunnan China
    2001 Prius
    Tow, baby, tow.
    If you had popped the fuse on a remote camping expedition (like with an outboard inverter) a jumper wire to get you back to civilization would be OK. Then you remove it, and Toyota doesn't use it against you.
  11. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    Peaquod-san, my name is Hiroko Toyogaga. Master computer has already been warned of your shennanigans, we are waiting for you. Boo-ah-ha-ha:eek:
    not
  12. Patrick Wong
    18,200
    6,472
    Hi Peaquod,
    It was a very clever idea to bridge the gap in the fuse link with the alligator clip. As you pointed out, other portions of the link remained available to protect the circuit. Since the temp fix allowed the Prius to become READY, I'm not sure why you felt the need to tow the car.
    Regarding warranty coverage or lack of same, this will be an issue only if your inverter fails in the future. Assuming you didn't botch the jump polarity, you should not have to worry about a failed inverter.
    Regarding replacement of the fusible link box, I had previously seen another poster share her experiences about what was required to do so. This sounds like a fairly difficult task so it is reasonable for you to entrust that to your dealer's tech.
  13. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    One hopes that you'll eventually tell the whole story, because
    I'll bet it's entertaining and could be a lesson to all!
    _H*
  14. Patrick Wong
    18,200
    6,472
    Hi Hobbit,
    Post #5 provides a link to the story. Basically the 12V battery died, the OP did not fully recharge it, it died again, and finally the DC/DC fuse link blew. The OP's hypothesis is that the battery had a bad cell (or maybe two) causing excess current to flow from the inverter to the failed battery.
    This is a reasonable scenario. A good reason not to mess around tolerating a weak or failed 12V battery especially in winter weather, but instead install a new one immediately given any signs of pending failure - like weak passenger cabin lighting, weird Prius behavior, etc.
