Will 'trickle-charging' my battery once per month=Make it last longer?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Nov 1, 2018.
  1. ski.dive
    ski.dive Active Member
    896
    231
    Hutchinson Island,FL. Mt. Snow,VT
  2. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    1. To what level (the equivalent of a full charge or for cell equalization?), and;
    2. Are you asking about your HV traction battery?
    iPhone ?
    49,492
    Depends
  4. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    If it's an old Hyrbid battery it could help it live longer... If it's an old 12v battery it might help, but not as much as with the Hybrid...
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    For the HV pack, IF you use a peak detection charger and do each module individually, most likely YES (or use a commercially available pack charger/discharger).
    For the 12v, doubtful.
  6. Usle
    Usle Active Member
    317
    139
    Me
    2018 Prius Prime
    Well, it won't die as fast as it would if it were being constantly drained, it will allow the ice to run less, because it's fully charged, of course letting it sit charging after it's fully charged isn't good for it, but a timed trickle charge or an intelligent trickle charger would avoid that provlem.
    Last longer?? Tough one.
    Better gas mileage, yes.
    The prime charges the 12v as it's charging the traction battery.
  7. PriusCamper
    11,105
    4,518
    Sure would be nice to redesign the bus bars with a mechanical switch so without removing the pack you could go between charging whole pack in a series vs. individual module testing, diagnosing and reconditioning. But my brain won't let me even think about what a sketchy hassle fabricating that would be.
