Wind noise of 2005 Prius
Discussion in 'Gen 2 Prius Main Forum' started by Minkowsky, Jun 10, 2012.
  1. Minkowsky
    Minkowsky Junior Member
    Santa Barbara
    I got a used prius 2005 last month. Everything with it is good but the wind noise from the left side of windshield. I tried to tape many place on left, but the noise still. Does anyone know the source of the noise?
  2. retired4999
    2,652
    623
    Eau Claire, Wi.
    Try the bottom of the mirror a small hole put a small piece of tape over hole. worked for my 2005.
    ArcticPrius likes this.
  3. direstraits71
    direstraits71 Member
    367
    62
    Central Coast California
    This has been discussed before, but I'm not sure what to search for the thread. Check the underside of the outside rear view mirror. It has some circular tape pieces over the mounting screw holes. If that tape is removed or damaged it creates a whistle. If your tape covering is missing or damaged, cover the holes with some new tape and see if that stops the noise. I hope that does it.
  4. JollyRats
    JollyRats New Member
    I just bought a used 06 and noticed a lot of wind noise at highway speeds. I bought two new seals from the dealer for the driver's door, installed them and while I was at it sprayed undercoat on the inside face of the outer sheet metal of the door. Now quiet ;) And the door sounds like a Lexus when it closes. All the other door still have that tinny sound when they close, but hey, I only use the driver's door )))
Loading...
