Wind Noise on brand new 2017 Prius
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by rstover, Jun 26, 2017.
  1. rstover
    rstover New Member
    Roseville
    Just bought the vehicle. At around 60 MPH, especially on the freeway there is quite a bit of wind noise coming from the front driver's side. Is this normal? Seems a bit excessive. Could there be a gasket or trim not installed correctly? My first post, Thanks!
    51,154
    welcome!
    try folding the mirror in and see if it changes, but i think there might be another thread about poor gasketing.
    RCO likes this.
  3. Ganden
    Ganden Junior Member
    Minneapolis
    I've had the same problem with wind noise from the driver's window. It's a loud, gurgling, fast ticking-type noise coming somewhere around the corner of the window where it meets the sill (closest to the seat belt). I bought the car in March and it was at the dealer three times trying to fix it with no luck (and no real concern from them). It's positively horrible. I drive 5-600 highway miles a week and am it's so irritating I'm thinking of selling the car just to keep some degree of sanity. Such a disappointment. I wonder if we have the same noise.
  4. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Oh dear, sorry to hear that, but you're not alone. Someone else has reported the problem this year. As I'm in UK, I'll wait for one of your fellow countrymen to advise on best action. @Tideland Prius on Canada is the moderator of the North and he may be able to guide you. If not, there will be others on the forum willing to help, so welcome to Prius Chat.
  5. Tideland Prius
    16,445
    I believe there have been one or two threads on this (because I remember someone putting a towel there to dampen the sound). It is disappointing. I haven't heard it much but I don't drive the Gen 4 often (The Gen 3 is my main car).
  6. Tande
    Tande Active Member
    523
    310
    Mich.
    Not trying to hijack this thread, but.......I do have a driver's door that does not Aline/close properly.......I see no way to get to the hinge/mount (for readjustment) without first removing the front fender! .....:mad:
    #6 Tande, Oct 29, 2017
  7. Elektroingenieur
    2,515
    3,277
    Three Touring
    When the door is attached in the assembly plant (YouTube video, from 5:08), the door hinges are already bolted to the body, and the door is mounted by installing four centering bolts to secure the door to the hinge. This explains why (on my car, at least) the body hinge bolts are painted and the door hinge bolts are not. Notice how the operator puts a protective cover over the edge of the door at 5:45 and removes it at 6:06; between these two steps, we hear the air wrench operate four times as he installs the bolts.
    The Repair Manual (available by subscription to techinfo.toyota.com), under Vehicle Exterior: Door/Hatch: Front Door: Adjustment, doesn’t mention having to remove any body parts, but it does say to replace the centering bolts used at the factory with standard bolts, available as service parts, when making an adjustment, and it gives the torque specifications for the hinge bolts on the body (26 N·m) and on the door (21 N·m).
    It also says to use a Special Service Tool, the Door Hinge Set Bolt Wrench, part number 09812-00020, a box end wrench with two 90° bends in the handle. I haven’t seen this SST myself, so I’m not sure, but this may be a misprint; the hinge bolts on my car are all 12 mm across the flats, and the SST is listed as a 14 mm wrench. The 12 mm wrench is 09812-00010.
    More importantly, the manual has an illustrated list of fourteen clearance measurements for the door, relative to the body and the rear door, and a standard range for each. If possible, I’d suggest finding the measurements that are out of specification, and then asking a dealer to adjust the door under warranty, so everything related to bolts, SSTs, damaged paint, stripped holes, etc., would be their responsibility.
    RCO likes this.
  8. Tande
    Tande Active Member
    523
    310
    Mich.
    Thank You for that info. ......that wrench, 09812-00010. may do it......wow!, $46.00 ......the "Latch" side (only) of my door needs to be raised, necessitating re-positioning the hinges on the body......sure do hate the idea of letting the dealer "Have/At/It"! ....:rolleyes:
    RCO likes this.
  9. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    That could have been me. I put a towel there to locate source of wind noise.
    Placing a towel on the front door quarter glass horizontal base area eliminated the wind noise.
    Never did pursue it with dealership though.
    The other source of wind noise was also from the sunroof. Basically when closing it from the vent postition it wouldn't seat correctly thus created wind noise, work around was to open sunroof in slide mode and then close it. But if placed in vent postition and closed again the wind noise would come back. Again , never bothered having the dealership tear down the sunroof over this. Not worth the hassle ;-)
    SM-N950U ?
    #9 Frederickdawg, Oct 30, 2017
    RCO likes this.
  10. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Appropriate song for this thread. I get by with a little help from my friends. Un high version.
    #10 ETP, Oct 30, 2017
  11. Tande
    Tande Active Member
    523
    310
    Mich.
    Ordered THE wrench.....got it.....job done.....happy camper! ;)......Thank You!, "Elektroingenieur"
    #11 Tande, Nov 2, 2017
    RCO and Elektroingenieur like this.
  12. Elektroingenieur
    2,515
    3,277
    Three Touring
    You’re most welcome, and thanks for letting us know how it turned out.
    Just to confirm (so I can ask for a correction to the Repair Manual), you used the 12 mm wrench (SST 09812-00010), right?
  13. Tande
    Tande Active Member
    523
    310
    Mich.
    Correct.......
    Elektroingenieur likes this.
  14. afsfmj
    afsfmj Junior Member
    California, USA
    2018 Prius
    Bought a new 2018 Prius One. Didn't drive it on the Highway before the purchase. When I was driving it back from the dealer, I noticed at speed above 55 MPH, a kind of irritating crinikling noise coming from the driver door, was not able to pinpoint it. Took it to the dealership, they said it is the rubber around the window. They will change it.
    Too bad, my first Toyota, and this happened. Seems QC is not good enough.
  15. xerox6135
    xerox6135 Member
    170
    93
    michigan
    You guys have convinced me no gen 4 for me .
  16. afsfmj
    California, USA
    2018 Prius
    I took it to Stevens Creek Toyota (San Jose), and they were able to considerably mitigate the noise. While my car was being serviced, I took a loaner which was a 2017 Prius Three, and I could hear the exact same type of noise in the loaner. Here is the service report, if any one is interested, with the part they replaced:
    F. DR GLS RUN 1 SIDE ~|~CUSTOMER STATES HE HEARS A LIGHT ANNOYING CRINKLING PAPER TYPE OF SOUND COMING FROM THE LEFT FRONT DOOR AREA AT SPEEDS ABOVE 60 MPH. CUSTOMER HEARS IT ALL THE TIME AT THOSE SPEEDS.CHECK AND ADVISE. ~|~WEAK SEAL ~|~217 C : HEARS LIGHT ANNOYING CRINKLING NOISE FROM LEFT FRONT DOOR AREA . C : I TEST DROVE VEHICLE AND CONFIRMED COMPLAINT . AFTER INSPECTION I FOUND NOISE COMING FROM L/F WINDOW RUN / SEAL . FOUND RUBBER TO BE EXCESSIVELY DRY AND NOT FLEXIBLE .REPLACED LE
    PARTS
    NAME
    PART # QTY
    RUN, FR DOOR GLASS, 6815147051 1
  17. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    I have wind noise in my gen 4, but it is significantly quieter than my gen 3 was.
  18. David Carnevale
    David Carnevale New Member
    North Carolina
    2019 Prius
    LE AWD-e
    I have a 2019 Prius wind noise starts around 45 mph. Toyota is aware of the wind noise, but does not have a repair solution, so they call it normal wind noise. Toyota told me to test drive a new Prius. Drove a 2021, wind noise at 55 mph. None of the master mechanics knew of this problem.
