Wind whistle noise coming from front speaker cover during speeds above 80km/h
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fviana, Jul 23, 2017.
  1. Fviana
    Fviana New Member
    Finland
    Hey guys, I've been going nuts with a wind whistle noise coming from the driver's side window during highway drive on my 2008 Prius. Then I noticed that by pressing the front speaker cover the whistle sound would disappear. So I then figured out that the only thing that could be affected by the pressing of the speaker cover was the vertical rubber seal between the cover and the window frame. So I took the cover out and put some tape over the rubber seal... And that was it, no more whistle noise on high speeds. I'll upload two pictures, one without the tape and another one with the tape. I hope this inexpensive solution helps anyone having the same issue. 20170723_141325.jpg 20170723_144200.jpg
  2. MikeBee
    MikeBee New Member
    I fixed mine with weatherstripping meant for a house. That noise was driving me crazy!
    Patrick Wong and Tommerdoo like this.
  3. Tommerdoo
    Tommerdoo Member
    81
    29
    Superior, WI
    I actually fixed mine by filling all the voids and gaps with "Greatstuff" behind the speaker. I had whistling on both sides going down the highway and now my Prius is so so so quiet on the highway. So nice.
    Patrick Wong likes this.
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Its the seals on the outer mirror. Like weather stripping on your home door, it becomes too compressed over time and is unable to maintain an airtight seal, allowing the outside elements to enter (air, water).
    Take a look at the attached pictures of the factory mirror.
    Old broken OEM mirror, the seals are FLAT.
    New OEM mirror, the seals are thick (approx. 1/4inch). Should have taken a side view to capture the thickness.
    Get some black rubberized weatherstrip at your local big box home improvement store.
    Something like this from Lowe's will work ($4.18): https://www.lowes.com/pd/Frost-King-10-ft-x-3-8-in-Black-Rubber-Foam-Window-Weatherstrip/3062421
    The "tape like" seals covering the screws, on the bottom, could possibly add to some wind noise, albeit slightly. My money is on the majority of wind noise entering the passenger cabin is due to the flattened outside door mirror seals.
    Patrick Wong, Tommerdoo and SFO like this.
  5. Patrick Wong
    18,200
    6,500
    Wind noise had been a problem on the driver's side of my 2007. Prior to finding this thread I replaced the tape covering the screw holes at the bottom of the mirror, no change. I spent $50 to replace the rubber seal that runs around the door, but that did nothing. Then I found this thread and applied one layer of electrician's tape as suggested by the OP, and that was sufficient to get rid of the noise.
    Tommerdoo likes this.
  6. lucecoast
    lucecoast New Member
    San Diego
    Thanks for your post - how did you remove the speakers? I'm having trouble finding anything online!
    Fredii likes this.
