Window Motor?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ePrius, Apr 6, 2015.
  1. ePrius
    ePrius Member
    162
    76
    Morning all,
    This past weekend, the driver side passenger window does go up or down. I tested my other window and they work perfectly fine. *Knock on wood* The window lock is off.
    Anyway I was wondering if anyone else had the same problem.
    If they did, was it an easy fix or do I have to take to a service center?
    Thanks!
    52,390
    does? or doesn't. if not, the drivers gets the most use, and is always the first to go. i would pull the switch and check for continuity. if it's okay, pull the door panel and check for power at the motor. if it's there, and nothing is jammed, look for a salvage or ebay replacement. shouldn't be too difficult, and there might even be a utube video. all the best!(y)
