Window Open notice
Discussion in 'Prime Main Forum (2017-2022)' started by Tickwood, Apr 27, 2022.
  1. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    For the last few days i get the notice "window open" when i get in the car, No windows are open and the notice goes away on startup. Has anyone else seen this?
  2. Graz
    Graz Member
    178
    28
    I only get "window open" notice when one of the doors is open.
    Via Prius Chat for Android
    Graz '21- Midnight Black Metallic Ltd.
    5/28/2021
    Graz '05 - Tideland Pearl - Package 6
    02/02/2005 - ???
    -gifted to son
    231,776 miles of smiles
    Lifetime: ~48.71 MPG Highest Tank: ~57.9 MPG Highest Miles/Tank: ~559
    P185/65R-15 Bridgestone Ecopia EP422 SL 42.0/40.0 psi
    OPTIMA Yellow-Top 12 Volt ACC Battery
    XChanged the Traction Battery at 184K
    Limit your funding of international terrorism!
  3. BiomedO1
    BiomedO1 Senior Member
    1,474
    796
    SacTown, Ca
    I get that notice all the time; but I do leave my windows open a quarter inch - to allow the cabin to breath. If all your windows are actually all the way up - you may simply need to recalibrate the window sensors. Roll them all the way up and down several times. Also check your 12 volt battery; it may need charging. Low battery voltage can cause it to forget sensor calibrations.
