Window Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by loonyhiker, Apr 11, 2009.
  1. loonyhiker
    loonyhiker Junior Member
    16
    The passenger side control will let the window go down but I can't get it to go back up. Only the driver side controls will get the window to go back up. Has anyone else had this problem? If so, what did it take to fix it? Thanks in advance for any info you can give me.
  2. bif
    bif Gas Saver
    Wyoming
    Sounds like you have a bad switch in the passenger door.
  3. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Yeah I'd say a bad switch. I see its a 2007, is it still under warranty?
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Haywire power window switch. I had another vehicle do that, only the switch at the driver door would work the left rear window. Fortunately that was also a warranty repair
  5. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Yup. Switches are mechanical and anything mechanical breaks. Unfortunately, nobody can manufacture 100% perfect parts. So, your switch died a premature death. Get if fixed under warranty.
  6. loonyhiker
    16
    Thanks everyone! We bought the extra 100,000 mile bumper to bumper warranty so I guess I will be getting it fixed! Appreciate your help!
  7. magruder
    magruder Average Member
    145
    Colorado
    The warranty approach sounds good. I don't have warranties on my cars, so I use the "jiggle the switch around real good until it works" approach. I have actually had very good success with this. I think sometimes dirt gets in there and cuts out the connection.
    Regards,
    Dave
