Window replacement car shut down?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JayGen4, Mar 16, 2020.
  1. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    Any idea why my car will not start or respond in any capacity to anything?
    Car was broken into from front passenger window. Window was in process of being replaced. Car drove fine between break in and replacement.
    Now nothing. So odd. Doesn't seem like the kinda thing that would be relevant to the issue. Either some freak coincidence or it is related.
    Gen 4 Prius 2. No Lane assistance or adaptive cruise etc.
    Tried disconnecting and reconnecting the 12v battery. Nothing. Out of ideas.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    I have no idea, but a wild guess. Car won't start if door is not closed. Maybe when they replaced the glass they interfered with the sensor that tells the car that door is closed???
    alanclarkeau likes this.
  3. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    Turns out by some freak coincidence the battery died. That's all.
    krmcg likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Welcome. That sure stinks about the break in. The shop most likely left the door open too long and killed your 12v battery. Did you measure it?
    kithmo and alanclarkeau like this.
  5. bisco
    52,382
    did they do the replacement in your driveway?
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Try charging it - it should still be fine for a couple more years.
    jerrymildred likes this.
  7. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    It was trashed. You would be right generally but this one has 126k miles already. That's about right for these. Got it to start a couple times but ultimately not enough to drive it.
    Glad it is fixed! It's unfortunate there isn't done indication the battery is nearing it's end before it happens because it is especially worrying and confusing and difficult when it happens.
  8. alanclarkeau
    7,045
    7,593
    As someone mentioned, it could have been because of doors being left open while the glass replaced. But - 126k miles is a good life, though the 12v battery only works to run the electronics and electrical functions - not to start the vehicle.
    I don't know of any car which has a 12v battery health indication - my experience is that they either get weak then die, or just suddenly die.
    JayGen4 likes this.
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Actually, the 12v battery does "start" the vehicle, in a way... ;)
    It powers the ECUs and enables the main traction battery to come online. But you're right, there is no starter motor. ;)
