Window rolls up then down.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Uberfast, Jan 4, 2017.
  1. Uberfast
    Uberfast Junior Member
    76
    Oakland , ca
    2014 Prius v wagon
    Hi folks.
    My window started acting funny. The driver's side rear window. This window will roll up then roll down halfway. I will then roll the window down and back up. The windows still persists to roll down halfway.
    Please help with a process. Thank you.
  2. Air_Boss
    Air_Boss Senior Member
    3,939
    1,076
    New Yawk
    Something is impeding the automatic closing. Check debris in the window tracks.
  3. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    I wish it was this simple. No to answer your question there is no debris in the window track. Thank you so much for looking into this and I appreciate your kind words
  4. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Folks, is there a reset process. I guess what I'm trying to say is. Is there a process in resetting the window
  5. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Here's the fix. I have a 2014 Prius V. The procedure is... First go to the window that's having the problem. Roll the window down and hold the button down for 5 seconds after it's been rolled down. Next roll the window up keep holding the button four five seconds after it's been rolled up. That should fix the problem. Then go to the driver side window control panel and test the broken window
  6. Air_Boss
    3,939
    1,076
    New Yawk
    The system is quite sensitive. if it senses a load, be it debris, the channel pinching slightly, or even stickiness (say, due to pine pitch), it will reverse to half open.
    If there is a process, it's likely remove the 12V power and treat it like allowing the automatic closing logic to re-learn. That may fix it.
  7. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Yes sir,
    I did disconnect the 12v source for more than 2 hours.
  8. Mendel Leisk
    38,644
    If you disconnected the battery, that's when it lost any "learning". If you then follow post #5 instruction, hopefully it'll relearn. See page 113 in Owner's Manual too (1-5. Opening and Closing Windows).
  9. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Thank you so much. It all worked well.
  10. Snags
    Snags New Member
    Australia
    Hi does anybody I how to fix 2014 Prius right hand rear window problem. The master switch only takes the window down not up the door controls work fine I have tried to reset as described many times but this doesn't work .. please can anyone help..
  11. Ed69
    Ed69 Junior Member
    38
    23
    CA
    If you disconnected the 12v battery and couldn’t fix it then the master switch is the problem. Especially if the right hand rear window switch actually works to go up and down. Something is wrong with the master switch and the part probably needs to be replaced.
  12. almostrice
    almostrice Atari Rocks
    33
    16
    Houston
    I just did door glass replacement and this fixed my problem with glass not going all way down and coming down after putting it up.
  13. Andy Gopaul
    Andy Gopaul New Member
    Trinidad and Tobago
    I replaced left rear window glass, after when carrying out operation of window, glass moving up, then goes to half way down and stop
    Please advise how to rectify this
  14. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    I seldom use the rear windows in my Prius v. Four years after I got the car, I had the problem of the driver's side rear window not going all the way up.
    I tried the reset procedure but it did not work. I took the car to my dealer with whom I have a very good relationship. They tried the switch procedure, too. They could not get it to reset.
    Apparently, the motor was not correctly "timed" at the factory. Even out of warranty, my dear's service department, got Toyota to pay to have it fixed for me, since they agreed that it was a factory assembly defect.
    Here is a link to how it is done, if you want to do it yourself. It does require removing and repositioning the motor and mechanism.
    How To Power Window Regulator Motor Reset Limit Switch - Toyota Sequoia Equipment
  15. Matt Scaggs
    Matt Scaggs New Member
    Bay Area
    Thank you - I replaced a broken rear passenger window on my '17 prime and this tip finished the job. Much appreciated.
  16. andresitogp
    andresitogp New Member
    Ecuador
    I signed up just to thank you!! This fixed it right away!
  17. DanWF
    DanWF Junior Member
    South Dakota
  18. DanWF
    DanWF Junior Member
    South Dakota
    Thank you. Fixed the issue.
  19. Pissedoff
    Pissedoff New Member
    Ga
    Dude this worked perfectly
  20. MsTurbo
    MsTurbo New Member
    Los angeles
    Thanks- this advice worked perfect for me!! I have a ‘2011 Prius.
    Air_Boss likes this.
