Window switch lights
Discussion in 'Prime Accessories and Modifications' started by captqc, Apr 5, 2023.
  1. captqc
    captqc Member
    70
    43
    Oregon
    2022 Prius Prime
    I was checking out another Toyota forum and came across a simple change to light up all the switches on the driver’s door that Toyota took away a few years ago. Part circled in green is the one that lights up all switches. Toyota p/n: 840400E130. Bought mine from a wrecking yard for $50 out of a 2022 Tundra.
    52,015
    that looks cool!
  3. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Good info, thanks. Here's difference between years.
    captqc likes this.
  4. captqc
    captqc Member
    70
    43
    Oregon
    2022 Prius Prime
    Thanks, it’s funny that Toyota dropped the “Auto” symbol as all four windows are auto up and down even on my 2022.
  5. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    how do you swap it out?
  6. captqc
    captqc Member
    70
    43
    Oregon
    2022 Prius Prime
    Super simple, just pry up the panel and arm rest with a plastic tool, unclip the wire connector, remove three screws, then reverse the process. Literally took ten minutes start to finish.
