Window Tint - Does it really help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dbacksfan, Jun 27, 2009.
  1. dbacksfan
    dbacksfan Member
    258
    22
    Scottsdale, Arizona
    2014 Prius v wagon
    Here in Phoenix, temperatures are now reaching 106 - 110* F. Does "good" window tinting really help in lowering the internal temperature of the car while it is parked? Will it help to reduce need for AC? Just wondering if anyone has actually read related studies.
  2. Prius_SGP
    Prius_SGP New Member
    58
    Saint Genis Pouilly, France
    Personally after I had my widows tinted I found that it helped a little - the main problem for me is that huge window screen - but a decent shield helps.
    On the day I got it tinted the temperatures outside were in the mid to high 80's. When I first got into it to go to the dealer it was sweltering. The next day similar conditions it seemed a lot cooler to me.
    The main benefit I found was that the light tint that I was able to have on the front side windows helped to reduce the glare - it's like driving with my tinted glasses on. (check your local laws with regards to tinting the front windows)
    The other benefit I found was that the tint helps to stop a lot of the light glare whilst night driving.
    For me it has helped - maybe not tremendously but it keeps the interior a more stable temperature.
  3. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Any car sitting in the sun will eventually reach or exceed ambient temperature inside (except for something like the Gen III with an active ventilation system). The reason I have tint is because it cuts down on radiative heat on my skin and on interior components. Like a heat lamp, there is a frequency band in sunlight that heats on contact, at the point of contact. Even with a good air conditioner, I find that sitting with the sun shining in through the side window is uncomfortable. The window tint filters out most of this frequency, much reducing the solar load on me - and on interior components, thus reducing the load on the AC. So it's more for that than for keeping the interior cool when the car is parked.
  4. darelldd
    6,057
    389
    Northern CA
    Oh man. I won't own a car without tint. EVERYTHING is better with tint - except night vision. You solve that by not going too dark. Tint increases the safety of the glass, it reduces glare, it lowers the load on the AC, it makes the interior more secure since it is hard to see into the car from outside.
  5. sarahrose0413
    sarahrose0413 New Member
    Scottsdale, AZ
    We live in AZ too, and I could NOT deal with untinted windows down here at all!! I had mine tinted in MN because of the glare of the snow in the winter, but it has helped a TON down here...wouldn't say it kept my car cooler, but definately made it easier on my eyes while driving. I will always tint from here on out...just easier on my sensitive little eyes, LOL!!:)
  6. wave_slider
    wave_slider New Member
    201
    26
    the aloha state
    Tint is a necessity in the islands. It's hot and humid. I could not live without tint. As it has been mentioned before, it also makes the glass less likely to go flying when broken and makes the car look better.
  7. 925PriusGuy
    925PriusGuy Winter Gray & Blizzard Pearl Pri
    148
    Northern California- SF East Bay
    I have both Toyota's tinted and highly recommend for all of the above mentioned reasons + I believe that it's personally helped me reduce finger-related road rage.. the tint can obscure how many fingers you are holding up when someone cuts you off because they can't juggle their latte, cell phone and turn signal at the same time :mad:.
    A lot of people I commute with must think that I wave at them when they do stupid things. :rolleyes:
  8. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    :) Definite difference! I wish I could tint the windshield! Have it done by a pro and it will be worth the $$ in upholstery, A/C, and perhaps even skin cancers on your arm & left side of face.
    Lee:cool:
  9. Radon
    Radon New Member
    120
    Vancouver
    Window tint also makes your interior last longer. At least for the back of your car.
  10. Jon S
    Jon S Member
    185
    84
    The Aloha State
    I understand that the windshield is treated to block UV. I now see that there are new transparent films designed to do the same thing (AIRBlue by Llumar). It has a very slight blue tint and is supposed to block UV and reduce the heat passing through by 43% and UV by 99%. I wonder how good this is....
  11. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I find it helps once in the car with the A/C going. The sunlight coming in and say hitting your arm skin through the tinted windows is not as hot, but if the car is parked outside, honestly, I find the car gets just as hot.
    I had a black 2006 and now a white 2010 both with tinted windows and I can tell you that exterior color IMO plays a very big difference. For me, I get the tint more for looks...
  12. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Just on a quick note, regarding the actual windows on the Gen III. I noticed that my skin didn't get as hot when the sun was shining through the side driver's glass. So I'm thinking that maybe all of the windows have been UV treated.
  13. wave_slider
    201
    26
    the aloha state
    I agree about the exterior color having the largest impact on heat. I tried to convince my wife to get white instead of magnetic gray on her Corolla for that reason. With the dark charcoal interior the car heats up and takes a while to cool down mid-day. We have to start the a/c on max recirculate and on the 3rd or 4th speed. I normally don't drop below 3 mid-day and she has 35% all the way around...
  14. syncmacd
    syncmacd Waxing is Relaxing
    SoCal
    The number you are looking for is the solar heat gain coefficient. This is a number between 0 and 1; the lower the number, the more heat is blocked.
    Madico Window Films (non ceramic)
    http://www.madico.com/WindowFilms/MAC_Specs.asp (ceramic)
    Often ceramic films do better with blocking heat, some people find that (older) blended metallic ceramics can also block cell phones and GPS, though the newer films supposedly have corrected that problem.
    http://www.tintdude.com/forum/index.php?showtopic=19816
    "Huper's ceramic may in fact cause problems with some electronics for these reasons, it contains a conductive ceramic derivative of titanium (a metal), frequency of the electronic equipment is of that able to be disrupted by HO film deposition and the density of the film used (meaning a heavier deposition)."
  15. wave_slider
    201
    26
    the aloha state
    I've seen a demonstration with the ceramic vs. non-ceramic tint using a heat lamp. You can feel the difference in heat coming through the tint. I will opt for ceramic for that reason. Also since the Prius has a lot of electronic "stuff" going on, I think it would be worth it to pay the premium for ceramic film this time.
  16. seanu
    seanu New Member
    West Palm Beach Fl
    I just did Huper Optik and it makes a huge difference in comfort, it was expensive but worth every penny.
  17. wave_slider
    201
    26
    the aloha state
    I just did mine in Llumar ceramic and I am very happy with it. It not only makes the car look better, but helps with the heat. I'm glad I got blizzard pearl and dark gray interior. My tint guy said that the ceramic does make a little bit of a difference for reception, but that he didn't think the price difference was worth it. I did ceramic anyway. What's an extra $100 when I spent $1800 on the NAV.
  18. Edward Walsh
    Edward Walsh New Member
    91
    Marystown, Newfoundland Canada
    Hi:
    When you get a chance could you take some 'pics' of your 'baby' and post them. I have a Blizzard Pearl coming the beginning of September and plan to tint the windows. Curious how it will look.
    Thanks,
    Edward
  19. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    scroll through my clear bra install and towards the end you will see the Llumar ceramic tint. the new Air Blue on the windshield and ATX50 on the sides and the rear.
    i am a big fan of Llumar.
    Collection: 2010 Prius
  20. liverbomb88
    liverbomb88 Push the Button!
    130
    16
    In a galaxy far far away...
    The Llumar Air Blue intrigues me because I'm not a big fan of dark tints. 3M also has a similar product line called Crystalline. I'm hoping both can also be applied to the windshield and remain CA legal. I'm starting to call around to the various tint shops in the San Diego area -- Mr. Tint in Escondido carries Air Blue...still looking for a shop that carries 3M Crystalline. Any recommendations on shops would be appreciated.
    Llumar Air Blue:
    Visible Light Transmittance: 78%
    Total Solar Energy Rejected: 43%
    Visible Light Reflected: 9%
    Ultraviolet Rejected: 99.9%
    3M Crystalline:
