Window tint on 2013
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Azonie, Feb 11, 2014.
  1. Azonie
    Azonie Junior Member
    I have 2013 and had windows tint. They did not tint lower hatch. Didn't notice much in winter since dark when I go to work and dark when I come home. But when I drive in daylight see diff in upper and lower hatch.
    Some say not to tint lower as will be issue with night driving. As lower is already darker than upper.
    What is everyone doing.
  2. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    My tint shop didn't tint that window for the same reason. Well, actually, they said it's because the window is plastic, which it isn't.
    Yes, the color is kind of strange, kind of pinkish or something.
    SCH-I535
  3. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I don't think my lower hatch window came tinted any darker than the rest of the car. Maybe, but I didn't notice.
    The window tint shop tinted it however, the same shade as my rear windshield and I don't have a problem driving at night with it tinted.
  4. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    I did not have mine tinted as the window is almost vertical. The question is, how much hot sun rays are going to come through this window when the sun would have to be a such a very low angle in the sky?
  5. Josh83
    Josh83 Junior Member
    Frankfort, KY
    I have my windows done with 20% all around, and had them put 35% on the lower hatch window. It is a VERY close match to the others with 20%.
  6. rannnddeee
    rannnddeee Junior Member
    32
    Carson, CA
    I just got my car tinted yesterday and I didn't get the lower hatch done. The rear windows are all at 5% and it actually helps not having the lower hatch tinted because I can see when backing up at night.
  7. mediahound
    903
    155
    Any pics? I'd like to see how it looks without that part tinted and with it tinted lighter.
  8. rannnddeee
    32
    Carson, CA
    20140301_143934.jpg 20140301_144357.jpg 20140301_144409.jpg 20140301_144445.jpg It just takes a lil getting used to seeing 2 different shades when looking at the rear view. From the outside it looks like they're the same shade.
  9. BZzap!
    BZzap! Senior Member
    1,607
    877
    I specifically did not tint mine. It's shaded pretty much by the spoiler anyway. Also, it would cause visibility problems. I have a long, narrow unlit driveway. Backing out would be a challange if that section was tinted.
  10. oldtone
    oldtone Junior Member
    Memphis
    Any change in radio reception after the the tint?
  11. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Mine are tinted top and bottom. I hate glare from headlights. The darker, the better, I say.
    Why would radio reception be affected by tint?
    iPhone ?
  12. Levelheadsteve
    Levelheadsteve Junior Member
    40
    I have two Priuses, both with tinted windows. The 2010 does not have the lower hatch tinted, but the 2012 does have it tinted. I like it much better tinted. I plan on having the 2010 lower hatch tinted when I have time. I have no reception or visibility issues with the extra tint and it is much better when a car is following to have the tint there.
    brn1981 likes this.
  13. Bingee
    Bingee Member
    210
    62
    Michigan
    Mine are all tinted top and bottom , perfect match , no issues
  14. TLCESQ
    TLCESQ Member
    30
    31
    Any recs re tinting? Cost, percentage/degree, etc.do not like having clear windows!
  15. robertk328
    robertk328 Member
    206
    36
    Northern Virginia
    I had mine tinted with Pinnacle series for $349 :)
    TLCESQ likes this.
  16. Bingee
    Bingee Member
    210
    62
    Michigan
    No regrets cost $ 275
    Check your state laws on tinting , I have a prescription from a doctor requiring tint due to eye troubles
  17. qdllc
    qdllc Senior Member
    1,370
    399
    Mine were done by the dealer. A popular option, so they put it on most every car they got. Worked fine since it met the max allowed by my state.
  18. LOLGuy
    LOLGuy Member
    177
    Tampa, FL
    I went with Formula One Pinnacle for the new 2014 III - Florida legal for the front and back (30 & 15, respectively) and 50 for the windshield (not FL legal but REALLY cuts down on the heat). Looks great.
  19. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    Factory VLTs are:
    74% rear hatch upper
    29% rear hatch lower
    I put 35% tint on upper and 75% tint on lower for effective net VLTs of:
    0.74 * 0.35 = 0.259 or 25.9% upper
    0.29 * 0.75 = 0.218 or 21.8% lower
    which is about as close as I could get to getting them to match.
    Appearancewise, they look about the same in terms of visible light transmission to my eyes, when looking directly at the glass (perpendicularly to its plane). They still appear different due to angle of the pane + glare (or higher ratio of light being reflected off the upper due to angle), and particularly due to the slightly different color cast in the factory glass (green on the upper, and gray on the lower).
  20. KeepitSimple
    KeepitSimple Member
    128
    Washington, District of Columbia
    Most films have metal in them which causes the vehicle to be a shell.
    mmmodem likes this.
