Windows wont work after disconnecting battery
Discussion in 'Gen 3 Prius Main Forum' started by BRYAN Rodriguez, Jul 16, 2019.
  1. BRYAN Rodriguez
    BRYAN Rodriguez New Member
    Eastvale
    I unplugged battery negative side and everything works accept my windows wont go up. 2013 Toyota Prius persona.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Have you tried to cycle them?
    Any recent damage?
    Any reason for removing the lead from the 12 volt?
    good luck and keep us posted (y).
  3. BRYAN Rodriguez
    Eastvale
    Thank you!
    Don't know what cycle means?
    I removed battery because I was working on steering wheel due that my charger fell in the crack of steering wheel and messed all my steering buttons, no horn no volume etc. So decided to take battery off, so I can work on steering. I then opened the fuse box in the drivers side panel and pulled one of the fuse and then I guess that's when window system stop working.
    Raytheeagle likes this.
  4. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    So you were able to put the window down after pulling the fuse but it now will not go back up?
    Just the driver’s window or all of them?
    And by charger, you mean a phone charger?
  5. BRYAN Rodriguez
    Eastvale
    I put all the windows down prior to starting my journey into taking off steering wheel. I disconnect battery. After reinstalling steering wheel back into place, I noticed that nothing again was working, so I decided to mess with the fuse box that's under driver's side. When I turned car my cars windows not working. And yes it was my car charger that was stuck inside steering wheel! I yanked out cord and probably messed everything inside.
  6. bisco
    52,348
    yeah, you're probably gonna need to remove the steering wheel again, unless the fuse blew
  7. ChapmanF
    18,497
    From the repair manual, section on re-initializing the window controls:
