Windshield marks from wipers - how to remove
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jared, Jun 5, 2008.
  1. Jared
    Jared Member
    209
    Long Island
    I just had my 2005 Prius washed in a car wash with the wax included. The windshield was clean at first, but when I put on the wipers, the right hand wiper left a very noticeable mark where it stops and reverses direction right in the driver's area of vision. There is now a white film there. Windex and paper towel did nothing to remove it. Some say Bon Ami is good. The wipers are new -just replaced and the fluid is rain-x. Any ideas of how to remove the marks?
  2. SparrowHawk60
    SparrowHawk60 Happy to be green!
    411
    Town of Newburgh, NY, U.S.of A.
    Try using some tooth paste to buff the marks out.
  3. Jared
    Jared Member
    209
    Long Island
    I want to avoid anything abrasive since that could ruin the windshield.
  4. richard schumacher
    7,663
    1,038
    United States
    In the hope that it's just really gooey wax, try some non-polar solvents: alcohol, Goo-Gone, paint thinner (keep that off everything except the glass!).
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    It's probably just road grime. I have used SOS pads (the kind with detergent in them) for cleaning my windshield. On the commute from Portland to Seattle I have had to use them as many as 3 times to remove the buildup. I carry a package in my Prius and they really work without any scratching problems. Aso all washer fluids are not equal. I tried RainX and went back to 20/10.
  6. Jared
    Jared Member
    209
    Long Island
    You must mean the plastic SOS pads (no rust). Steel ones would scratch glass horribly.
  7. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    If there is any dirt buildup on the wiper blades, especially sand, that will easily scratch the glass
    Drag your fingernail across the mark. If it feels like your finger is catching or dragging like in a groove, the windshield is badly scratched.
    If it feels more like a residue, that can be removed with either a paint scraper or patient buffing. Experienced window techs can use polishing compounds to take those marks off glass, no need to replace a windshield
    The worst windshield marking I have ever seen was from a friend who had his car repainted. They used sandblasting media to clean off the paint near the pillars, and the windshield cover had slipped. The edge of his windshield became opaque
    He hunted down a good window shop and they were able to polish out most of the opacity. Of course, a slight haze was always there
    I looked around and Eastwood Co has such a kit
    Eastwood Co. - Glass Polishing Kit Pro
  8. Jared
    Jared Member
    209
    Long Island
    Thanks. It is not a scratch, it is a line of white haze just along where the right wiper stops. (Wax from the car wash?) I think I will try Bon Ami. Also, I think I will not get Rain x washer fluid again.
  9. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I asked about water spots (somewhat related) and grime on windows to my friend a professional window washer. He said use white vinegar mixed with water, what ratios I do not know at this time.
    ZC1
  10. Jared
    Jared Member
    209
    Long Island
    Success! Thanks for all the advice. I got a no-scratch sponge, Bon Ami and paper towels. After some fairly hard rubbing with the wet sponge and Bon Ami, the mark was gone. The paper towels were black even though the car was just washed. (But then I do drive 100 miles a day on 8 lane highways). Bon Ami is a good friend.
  11. SparrowHawk60
    411
    Tooth Paste is not as abrasive as you might think it is.
    There are some commercial window polishes on the market..
    I'd avoid the harsh chemicals some have mentioned, you don't want to take a change that some of it will drip on to your plastic trim or the car finish!
    Boni Ami or a glass stove top cleaner may also work. Try some Baking Soda.
  12. eclipse3g
    eclipse3g Junior Member
    63
    You can also go to an auto parts store or automotive paint store and get a "wax removal product" this is what some of the paint shops use to prep the surface of a car before painting. Its a liquid like car wash concentrate you mix into a bucket of water.
  13. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    You want to avoid abrasives that are strong enough to polish the glass, as an inexperienced user can introduce optical defects that will ruin the windshield, but you need something strong enough to remove the film.
    Some people I know clay the glass on their car. I've never done that, but I have used the Diamondite system with "spray clay" (not the polishing cream, which the inexperienced user should avoid). Pricey, but it will do the job.
    Diamondite Spray Clay, Diamondite Glass and Surface Cleaner, Diamondite Shield, Diamondite Speed Clay
    Zaino Z-12 and DP Glass Restorer would probably work too:
    Z-12 Clear-View Glass Polish: Zaino Store
    DP High Performance Glass Restorer actually removes etched water spots from glass and restores perfect clarity. DP High Performance Glass Restorer can also be used to remove sap, bug splatter, and films from chrome and windows.
  14. Mark in NY
    Mark in NY Junior Member
    Long Island, NY
    After all this time and many experiments I have found a great fix for this-
    Soft Scrub with bleach.
    A quick rubdown of the windshield with rather light pressure with a rag wet with soft scrub removed all traces of rubber residue on the glass. Rinsed off and it looked like the day I took it off the dealers lot.
  15. Mendel Leisk
    38,724
    Product description includes the expression "mild abrasive", which makes me leery.
    I like this stuff, not sure if's just Canadian though:
    Kleen-Flo | Products - Glass Kleen
    Reading the ingredient list is a little depressing though: use sparingly and with good ventilation. This ingredient is a known carcinogen:
    2-Butoxyethanol
    #15 Mendel Leisk, Feb 3, 2020
