windshield washer fluid - hazardous?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gaitau, Feb 6, 2006.
  1. gaitau
    gaitau New Member
    we are so glad to found this forum. we moved here from california last year and purchased a prius last december. yesterday, we finally used up all the winshield washer fluid because of the snow and rain. however, when we went to get some anti-freeze washer fluid, we noticed that the bottle has a crossbone skull on it and it is labeled as poison. back in california, we used plain water as washer fluid for our previous car because the temperature never fell below zero in the area where we lived. so, we got some possibly ignorant questions about anti-freeze windshield washer fluid:
    is anti-freeze washer fluid safe for the environment? is it safe for the paint of the car? if we touch it, do we need to wash our hands immediately? is there a brand that is safe than others? how do we use it?
    any comments and suggestions are greatly appreciated!
  2. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    If I am not mistaken the skull and cross bones are because most of the cheap anti-freeze windshield washer fluid contains methyl alchol. If injested can cause blindness and othe digestive problems.
  3. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    Good question! I do think anti-freeze is poisonous as I know that dogs can die if they drink it and that it’s sweet so that they are tempted to do so. I don’t know how much they need to drink though.
    I don’t think it’s dangerous to touch (you probably have to consume a gallon to feel the effects) and I don’t think it’s dangerous for your car paint.
    I also suspect that you must use it as normal water will freeze. I would be interested in an environmentally sounder alternative that worked. I have never seen one.
  4. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    If it uses Methanol, yes it's very toxic, and also dangerous to pets and wild-life.
    There are fluids available that use other anti-freeze components that are much less hazardous.
  5. SomervillePrius
    944
    Somerville, MA
    OK, gotta go double check mine....
  6. gaitau
    gaitau New Member
    hi tempus, do you have any specific components in mind? i searched the Web but only found alternatives for summer driving. i hope the heated fluid innovation would become more popular soon.
    we just feel uneasy to use some chemical that is known to be poisonous and spray/spread it all over when we use the wiper.
  7. jeromep
    jeromep Member
    827
    Eastern Washington State
    As much as I think heated wiper fluid is a nice touch, it will most certainly not be heated when the vehicle is off, and that means that fluid in the lines or pump can still freeze making a mess of the washer system. That means that we will have some form of alcohol in washer fluid for a long time to come.
    I guess I'm not as concerned as many, however in our lives we are surrounded by and use poisonous items every day. I'm sure you can find less poisonous wiper fluid, however I'm sure it will cost a lot more and it might not be as effective. If you use your washers a lot that means you will be paying a lot more, too. Vehicles are filled with poisonous or harmful fluids. All coolants are poisonous. I wouldn't be out there drinking motor oil, or gasoline. I don't think that transmission fluid is much better either. And I'm inclined that knawing on the plastics of the engine compartment aren't going to be good for you either.
    I think it would be better to purchase garden variety washer fluid use it as directed and place the partially used container in a place where children or pets won't get to it. In addition, many brands of washer fluid use child resistant caps.
    As a suggestion, during the summer you can dilute down your washer fluid with water. That can be helpful as sometimes it is quite soapy, more so than you actually need. However in the winter you will want to go back to a full strength solution.
  8. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    MeOH is pretty quick to evaporate, really.
    blindness only happens if ingested orally. i get strong whiffs of that stuff all the time in lab. it's not pleasant, but does not pose a danger to your vision.
    i believe antifreeze contains ethylene glycol, which is the poisonous component. i should know what it does, but i'm a pharmacologist in training, not a toxicologist in training. :)
  9. lisamarie
    lisamarie New Member
    66
    Fayette County, PA (50 miles SE of Pittsburgh)
    I am a psych RN. I've known several patients who tried to kill themselves drinking anitfreeze (and one who succeeded). One of the MD's said that the main reason one of our patient's attempts had been unsuccessful was because the patient had consumed a large amount of alcohol around the same time he decided to drink the antifreeze. Had he been sober at the time, the patient probably would have died.
  10. Tempus
    1,690
    Washington DC
    I know 303 makes washer fluid replacement tablets. I don't know about their anti-freeze properties.
    I also know there are recipies out there for rolling your own using Isopropyl Alchohol and Detergent.
    I'm not sure about specific generally available cold-climate low-temperature prepackaged ones, but I'm curious now, I'll start looking :)
  11. priusblue
    priusblue New Member
    152
    That's correct - Antifreeze and antifreeze washer fluid are 2 different things. The methanol is what makes the washer fluid "antifreeze" because it has a freezing point of -98 C( -144F) The washer fluid doesn't have any actual car antifreeze in it (ethylene glycol or propylene glycol). I wouldn't worry about it too much. Just don't let anyone or anything drink it. It has a very low vapor pressure, and evaporates quickly. Methanol is just a methylene group away from ethanol and ethanol is toxic, too, but people drink it all the time! On a separate note, propylene glycol is the less toxic of the two types of actual antifreeze.
  12. priusblue
    152
    Isopropanol works, too as a washer fluid "antifreeze". Its freezing pt is -88.5 C( -127.3 F). I actually make my own washer fluid by taking my "homemade" window cleaner: water, isopropanol, and vinegar (can leave out the vinegar) and diluting it a little bit. This is really inexpensive. Isopropanol still is not something you want to drink or let others drink, and still has the same health rating as methanol (2 on a scale of 0 to 4 with 4 being worst), but is readily available.
  13. galaxee
    9,810
    465
    MD
    most of the time, anything fun and dissociative (like etoh :lol:) can be toxic in high doses. pretty much anything is toxic in high doses.
    methanol isn't metabolized as nicely by ADH- unless of course you don't mind a little formaldehyde running around your body, and eventually formic acid. yum. acetaldehyde and the eventual acetic acid are the much more friendly products of ethanol metabolism, and can even be used in cellular metabolism.
    i don't know anything about where meoh acts before it's metabolized- but etoh has so many different sites of action, and serious injury really results more from cns depression and/or hepatic toxicity than from metabolites.
    here i just went and hijacked the thread. sorry, folks. :)
  14. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    That is nothing compared to the dangers of Dihydrogen Monoxide. It's all around us and no one is aware of the danger. Thousands dead each year. Just check this out. http://www.dhmo.org/facts.html The horror of it all!
  15. smackoww
    smackoww Junior Member
    60
    *eye roll*
    technically, DHMO is the most abundant green house gas. now theres food for thought. and did you know that DHMO is the one of two major car emissions? the other is CO2
  16. gaitau
    gaitau New Member
    it's been very helpful and educational. thanks, everyone!
    by the way, we live just north of chicago now...so, no, our molecules are still intact ^_^
