Windshield washer motor
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by gomboy60, Oct 3, 2017.
  1. gomboy60
    gomboy60 Junior Member
    Tracy, CA
    Hi all,
    I have 2012 V with 120k miles on it and front windshield washer motor is not making any sound. I have checked the fuse of 15A under the left foot well and it was intact thus I am suspecting it might be the motor.
    Does anyone know where the pump motor is situated or is anyone having similar issue?
    Thank you.
    Chris
  2. Tande
    Tande Active Member
    502
    302
    Mich.
    Well......had mine quit also (2010 Prius)......pump motor is mounted directly to the fluid reservoir......remove the right/front wheel/well/liner & you're looking at it....(y)
  3. a1pharm
    a1pharm New Member
    Wisconsin
    Did it used to work for you and now it doesn't, or is this a "new" used car to you?
  4. Tande
    Tande Active Member
    502
    302
    Mich.
    Yes......purchased car new in 2010
  5. bisco
    49,492
    try tapping it with a hammer, sometimes they just get stuck.
