Windshield washer reservoir
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenjack, Feb 16, 2014.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Added fluid last week. Next day, wouldn't work. Temps below 20F. Checked bottle which said "Summer Mix". Didn't even know there was such a thing. It's working now after thaw and refill, but not sure if reservoir is cracked. Part appears to go for $75. What's invovled in a diy replacement.?
  2. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Wouldn't worry as long as the winter solution doesn't leak. You'll know in a day or two.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    If you need to replace it, I believe it involves undoing about 3 bolts and a clamp. Pretty easy.
  4. lenjack
    804
    114
    Pennsylvania USA
    I think it is OK, just lokking in advance if not. Thanks. "Summer Mix"??? Howda thunk it?
  5. Mendel Leisk
    38,707
    I just use the freeze-protected stuff year 'round, since it'll sit in there for six months or more.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    They also make different below zero temp. washer fluid. 0 or above, -15 below, -25 below. all kinds to try.
    I use -25 below in the winter here in Wisconsin.
  7. lenjack
    804
    114
    Pennsylvania USA
    Agreed...it's the obvious solution (unintentionable pun). Summer mix should be outlawed!!!
  8. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    I agree I don't ever recall seeing summer mix (no alcohol?). What I did for driving thru the PA mountains during the polar vortex, I added a bottle of isopropyl alcohol. They said on radio you could do this to boost anti-freeze level. I guess they said this would help stop freezing of the fluid on the windshield.
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yep! I always add about 2 cap fulls per gallon and in the winter months that is added to the winter -25 below washer fluid.
  10. bisco
    49,438
    i would sue them for even having summer mix on the shelf this time of year.:cool:
  11. xliderider
    7,869
    3,116
    Honolulu, HI
    If he's anything like me, the washer fluid was purchased a long time ago, then sat in the garage till needed. :p
    SCH-I535
    retired4999 likes this.
  12. lenjack
    804
    114
    Pennsylvania USA
    right, that's what happenned.
