Windshield Washer Won't Squirt
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Apr 2, 2017.
  1. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    My passenger side windshield washer only dribbles a little. Driver's side is fine. Anybody know how to fix this?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    When it happens to me, it's usually some lime or calcium buildup right at the nozzle. I find a fine wire, and ream it out.
  3. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    A sewing needle works great.
    jerrymildred likes this.
    52,382
    is a paperclip too big?
  5. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    I usually use a needle or pin.
    kenoarto likes this.
  6. jerrymildred
    11,517
    14,157
    Tampa, FL
    It's always been too big for the ones I've had clog up. I pull a strand out of some thhn multi strand wire or something. Also, maybe the wire from a parts tag, if you know what I'm talking about. Stripping a twisty tie from a bread bag might work. I just now thought of that.
    HPrimeAdvanced and bisco like this.
  7. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    One of best ways is to install inline filter so that will never happen again...i use small type fuel filter with washable stainless screen...
  8. davids45
    davids45 Active Member
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day,
    I've had this happen in previous vehicles but usually I blame the local biosphere (ants, algae, etc) that 'grow' in the seasons when the washer nozzle is less frequently used .
    Our tap water is quite 'soft' here ('soft' = a chemical term for fresh water relatively low in calcium and magnesium ions) but the goop here seems darkly coloured if I happen to see it during its extraction with a pin, paper-clip or thin wire.
    So 'diagnosis' a little different but the 'cure' is the same.
    If you do have 'hard water' in your taps, and this blockage does happen too often, maybe a little Calgon or softener could help. De-ionised water might be a bit of 'over-kill'.
    The normal windscreen-washer additives being surfactant solutions would also reduce a water-hardness problem I expect, but maybe not blockage with bug or plant stuff (I add a little store-bought washer solution when I remember during tap-water washer-reservoir refilling).
    If you car "situation" is like mine o_O , if it's the passenger side windscreen that is not clean and the passenger is complaining about not be able to see where you're driving :rolleyes: , get "her" to drive, or sit in the back behind you ('good luck' with that one!). Saves on pins, needles and wire - not necessarily the marriage, of course ;) .
    David S.
    Data Daedalus and jerrymildred like this.
  9. bisco
    52,382
    i only use bottled ww fluid, is that a better, albeit more expensive approach?
    Data Daedalus likes this.
  10. jerrymildred
    11,517
    14,157
    Tampa, FL
    I usually do the same. As @davids45 said, it can be biological. I think most of my clogs have been when I cheaped out and used tap water. I doubt it's been more than a half dozen times in the 45 years or so that I'be been driving.
  11. bisco
    52,382
    my tap water would clog a garden hose.
  12. jerrymildred
    11,517
    14,157
    Tampa, FL
    ROFLOL!! I love hyperbole. Especially when it's true. :ROFLMAO::ROFLMAO::ROFLMAO:
    Seriously, I know a guy who had to move away from the Tampa area because, after years of kidney stones, the doctor figured out that it was the water here. I guess he didn't want to buy bottled water. Or maybe it was just as bad.
    #12 jerrymildred, Apr 2, 2017
  13. bisco
    52,382
    yeah, i wouldn't drink this water. probably shouldn't even make coffee with it. lo ph, hi nitrates, sulfides, manganese, iron, you name it. it's clear and smells okay though.:rolleyes:
  14. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Ditto. I only buy premixed window washer with antifreeze additives from an approved store. Works wonders, summer or winter. Except last winter, while "The Spaceship" was being serviced, some dolt poured ordinary water into the ww tank, and on a few cold freezing mornings, my nozzles froze for the first time ever. I was both horrified and livid when I found out what had caused the window washer operations to fail. Thought the motor had died!
    iPhone ?
  15. jerrymildred
    11,517
    14,157
    Tampa, FL
    Good point on the freezing washer fluid! Happened to me once when I made a winter trip from Florida to Ohio. Not fun trying to drive through Columbus, Ohio in the dark, in a snowstorm, with frozen Florida washer fluid. I was plenty ticked!! The whole tank was frozen solid when I got there. Thankfully, nothing broke.
  16. bisco
    52,382
    rebound's problem is, he's too smart to leave sunny california, so he doesn't need pre mix w/antifreeze.
  17. Rebound
    3,996
    2,645
    Portland, OR
    I buy only the premix, which, I assume has antifreeze here in California. Sometimes, Californians drive to Tahoe for skiing.
    HPrimeAdvanced and jerrymildred like this.
  18. ETC(SS)
    7,350
    A straight pin usually works for my other vehicles, although I also have access to ittsy-bitsy wire.
    I've also heard where people can use vinegar or CLR either wiped onto the face of the nozzle or you can remove the nozzle and soak.
    Sometimes all you need to do is wipe the face of the nozzles with a rag to remove old (or new) wax deposits.
    Obviously you'll need to test plastic and paint if you use chemicals more aggressive than vinegar.
    3 Ways to Clear Clogged Windshield Washers - wikiHow
    Good Luck!
    txducker likes this.
  19. Mendel Leisk
    41,894
    Toyota dealerships up here sell the Toyota washer fluid. The bottle touts superior freeze protection and cleaning ability, just under $4 Canadian for four liter bottle. Bonus: it's pink, colour coordinated with the coolant. :)
    Well, except you can't see the washer fluid reservoir bottle, but you sleep better at night, just knowing. :ROFLMAO:
  20. jerrymildred
    11,517
    14,157
    Tampa, FL
    I thought about mentioning CLR as a possibility. But, since I haven't actually tried is, I was a little leery to recommend it since I don't know if it would attack the plastic.
