Windshield wiper problem
Discussion in 'Gen 3 Prius Main Forum' started by Shamrock 33, Nov 20, 2019.
  1. Shamrock 33
    Shamrock 33 Junior Member
    Dublin Ireland
    Hi , my wipers only work on fast mode ,, sometimes they barely work on slow / medium..... any ideas of what might be wrong,,,,
  2. Shamrock 33
    Dublin Ireland
    Sorry should of said it’s a 2013 gen 3 Prius
    49,429
    welcome!
    that will take some testing. it could be the stalk, or there maybe a pc board on the motor.
    best bet is to look at the troubleshooting in the service manual
  4. Shamrock 33
    Dublin Ireland
  5. Shamrock 33
    Dublin Ireland
    Thanks for the welcome ,,,,, yep it’s a pain , I don’t no where to start or what to risk buying first ,,,, rotten luck I suppose ....
  6. bisco
    49,429
    agreed. try finding a service manual on line, or at a library. if not, it is $20. for two days at techinfo.toyota.com
  7. Mendel Leisk
    38,700
    The repair manual doesn't have a lot of troubleshooting, basically connecting 12 volts to various pins and seeing how it performs, low and high speed.
    Replacement wiper motor is around $144 USD on this US site:
    Wiper Motor - Toyota (85110-47240) | Toyota Parts
    Part number is: 85110-47240
  8. Shamrock 33
    Dublin Ireland
    Ok thanks for reply’s anyway ,,, I did get a quote for an original motor from Toyota here in Ireland and it was 417 .00euro inc vat .... so it definitely won’t be an original going in if needed ... was the one specefied above a brand new one or second hand ?
  9. Mendel Leisk
    38,700
    I'm sure brand new. Things are surprisingly cheap in the States, frustrating. Perhaps search for that part number in your locale and see if anyone can do better.
    Try Amayama, just feed in the part number at their main page, see what it would cost shipped to you. They ship international; I've used them once for a small item and it went well.
  10. Shamrock 33
    Dublin Ireland
    Great thanks I’ll check it out
  11. bisco
    49,429
    not pharma :cool:
  12. Alan Richard Bradley
    Plymouth
    Hi Shamrock33 I have the same problem as you, have you solved the issue yet?
  13. AzWxGuy
    AzWxGuy Weather Guy
    982
    495
    Tucson, AZ
    2021 Prius
    This also could be a symptom of a weak 12V battery. The 12V battery is essential for the proper booting of the various computers and ECU's in the vehicle. Especially in the first few seconds after pressing Power. I would pull the battery and have it bench load tested. If it is the original, it's about time for a replacement in the 6-7 year time frame. Just something else to consider.
  14. redu
    redu New Member
    Denver
    Hello everyone, my windshield wipers keep wiping randomly without me touching it when it’s cold outside. I changed the fuse but it keeps wiping. Thanks
