Windshield Wipers.....
Discussion in 'Prime Main Forum (2017-2022)' started by LouG123, Dec 11, 2017.
  1. LouG123
    LouG123 Member
    49
    47
    Vernon Hills, IL
    I feel kind of stupid putting this question on the main forum, but here it goes.....
    I need to replace my front wipers, but when I initially went to remove them they seem to utilize an attachment to the wiper arm unlike any I've ever seen. I normally use Anco Transform blades as they are the closest to OEM for the Toyota Highlander (and were for my former Camry). I'm curious to know where owners have purchased new wiper blades and if you're using OEM or OEM style vs aftermarket...
  2. Mark57
    2,945
    2,740
    OK
    The manual p.624-625 explains how to replace the rubber only. You might have to go rubber only inserts.
    HPrimeAdvanced likes this.
  3. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Mr. LouG123,
    I contacted Aaron at The Toyota Place in Garden Grove who said they have to order any parts related to the windshield wipers. We don't get rain out here!
    The prices are as follows,
    for the full wiper blades,
    Driver's side: $21.39
    Passenger's side: $24.33
    For just the inserts,
    Driver's side: $12.52
    Passenger's side: $13.56
    Prices are plus tax, and shipping?
    Good luck!
    They have instructions on the packages I've seen, but you better make sure.
  4. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    Dang, you have gone thru a set of blades already?
    Mendel Leisk and HPrimeAdvanced like this.
  5. LouG123
    LouG123 Member
    49
    47
    Vernon Hills, IL
    Many thanks guys...
    HPA - many thanks for the legwork....unnecessary but very much appreciated....
    I brought my Prime Advanced home to Chicago from New Jersey on June 21st. I’ve just hit the 10.5k mile mark this week (I don’t normally drive this much, but I love this car). My original wiper blades are fine, but I always keep a spare set on hand, especially during the winter. I usually change out each car’s blades every six months or so....
  6. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    Our Prime and our Mazda have the same blade connectors. I have not found any aftermarket blades that fit. The dealership parts counter has replacement inserts.
    Trico calls similar connectors 19 mm push button. Anco calls similar connectors 19 mm bayonet. The other makers have their own names. None are exactly the same as ours, and none fit.
  7. bresna
    bresna Active Member
    193
    144
    Southern Maine
    I always use replacement rubber from Toyota. I find that they last fine and the stock blades seem to chatter less on the highway. Cheaper too.
  8. Mendel Leisk
    41,898
    Keep the windshield glass well cleaned, look into automotive glass cleaner, and you likely won't need fresh wiper blades for at least 50k miles.
  9. LouG123
    LouG123 Member
    49
    47
    Vernon Hills, IL
    I only use Stoners Invisible Glass for my cars. The problem isn't the glass cleaner, it's the ice and snow that wear down the rubber. This and the rediculous swings in temps that we sometimes get here. Besides, I'm rather OCD when it comes to the cleanliness of the windshield, so I may use mine more regularly than others.....
  10. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    I just posted in another thread on this topic on Gen4. It uses the same wiper blade as PRIME. As you said it, I also keep spare wiper blade in my car. See post #17 Gen4 wiper blades? | PriusChat
  11. Mendel Leisk
    41,898
    I use just cleaner, no coating. This stuff from Princess Auto:
    Smells kind of like ether. Google:
    Glass Kleen Industrial Strength Glass Cleaner
  12. LouG123
    LouG123 Member
    49
    47
    Vernon Hills, IL
    So I'm bringing this thread back from the dead.....
    During my 20k mile service, I asked the tech to just put in new wiper inserts, but the tech couldn't figure out how to get the factory blade inserts out. I'm embarrassed to admit that I can't either, as I can't seem to figure out how to get the end-caps off the wiper blade. Any thoughts? The blades aren't horrifically expensive, but the inserts alone are still almost half the price....
  13. Salamander_King
    11,024
    8,970
    New England
    I haven't done it myself, but according to the owner's manual on page 625, you are supposed to be able to just pull the rubber out of the end cap as shown in the diagram, then pull it out. Now inserting the new one might be a challenge if you can't slide it in, but the manual says to "firmly insert the wiper rubber groove through the slit and the fit the end of the wiper rubber in the groove of the cap to secure the wiper rubber". I think you have to just force it in rather than sliding it in. Yeah, it seems changing the whole blade assembly is much easier.
    Wraiththe and Mendel Leisk like this.
  14. LouG123
    LouG123 Member
    49
    47
    Vernon Hills, IL
    ^^^^^ Thanks for this SK....
    Never did I ever think an automobile owner's manual would reach 625 pages ! Never woulld my ADD have allowed me to get that far....Many thanks.....
    Salamander_King likes this.
  15. Mendel Leisk
    41,898
    Download the the pdf, and then you can search it, say for "wiper". Keep in mind it tends to use uncommon language, calls it "wiper rubber" for example, so keep your search simple.The table of content has hyperlinks too I believe?
    Google "toyota tech info", it's usually the first hit. There's a link called "manuals", and there you go.
  16. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    Or go here: Toyota Online Owners Manuals and Warranty. Manual is searchable and page numbers are hyperlinked in the table of contents and throughout the text. I keep a copy on my phone for quick reference.
  17. Mendel Leisk
    41,898
    That link is down right now, but same thing can happen with Tech Info. Yeah the more the merrier. (y)
  18. PT Guy
    1,085
    712
    Trico call the attachment Push Button FZ. Other aftermarket blade makers may have a different name for the same connector.
    Trico Exact Fit 28-17B (left front) and 16-17B (right front) are listed as the correct sizes. NAPA stores sells Trico with the NAPA label and may have the same blades.
