wining noise
Discussion in 'Gen 2 Prius Main Forum' started by JPM199, Feb 10, 2013.
  1. JPM199
    JPM199 Junior Member
    Developed a wineing type noise in my '07 prius engine compartment. Noise only there when gas pedal pressed. If I let off on gas the wining noise stops. Anyone else experience this?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Need more specifics: What speeds, is the ICE running, or just electric power? How does the car drive? MPG?
    The inverter does make some high pitched noise when larger amounts of current flow through it, but it is normally hard to hear.
    To be more correct, in the Prius there is no gas pedal per se, since sometimes pressing it won't turn on the ICE. Accelerator pedal is better.
  3. JPM199
    Car drives just fine ---- current load of fuel at 52mpg. The whine noise is heard whenever you let off the accelerator at any speed. ICE is running when whine is heard.
  4. nh7o
    1,686
    340
    Hawaii
    Confused now. Happens when stepping on pedal? Or letting off pedal? The two posts differ.
  5. JPM199
    Letting off pedal.
  6. nh7o
    1,686
    340
    Hawaii
    OK. Does the pitch of the noise vary with speed? I.e higher frequency with higher speed?
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    The engine is making the noise for sure. Put the car in inspection mode and the engine will run without you being in the car. Get a flashlight and open the hood and see where the noise is coming from. Items of interest are the engine water pump and the belt area. If whining in the front of the motor shut the engine off and look for green specks in that area indicating coolant seepage from the water pump weep hole usually indicating a bad pump. Check engine oil too.
  8. nh7o
    1,686
    340
    Hawaii
    I'm not convinced yet. If the car is warmed up, and the going less than 42 mph, then letting off of the accelerator pedal will cause the engine to turn off, zero rpms, and regenerative braking will occur. If going over 42 mph, the engine will freewheel at some speed, and also regen braking occurs. Since the OP says the noise happens when letting off the pedal at any speed, I would tend to think this has something to do with regen braking. That's why I am curious if the pitch of the noise changes with speed.
    Also, the OP could say what the mileage of the car is. Did the noise just appear one day, or come on gradually?
  9. usnavystgc
    3,159
    989
    Tucson, AZ
    Well, I've never hear wine make a noise before (unless you pour it) so the OP must have meant "whining" noise
  10. JPM199
    Missed letter when spelling whine. That happens sometimes when using smartphone keypad.
