Winter gas and fuel trims
Discussion in 'Gen 3 Prius Main Forum' started by Spooled, Nov 12, 2018.
  1. Spooled
    Spooled Member
    142
    25
    Concord, CA
    Is there any benefit to resetting the computer to optimize if for winter fuel? does it continue to "learn"? I also changed wheels so in my case maybe more beneficial to have the computer start over. Thoughts?
  2. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I reset the mpg history each summer/winter. Is this what your talking about?
    49,441
    not that i have ever read
  4. Mendel Leisk
    38,708
    I think OP means to disconnect the 12 volt neg cable for a minute or so.
    I've done that when doing brake work, and the next few start ups (two or three), it does an unusual rev-up, for maybe 15 seconds. I'm thinking it's testing something, re-establishing some parameters.
    My 2 cents, I wouldn't bother doing this seasonally, but who knows.
  5. ETC(SS)
    6,553
    Ignore the MDF.
    Those values are only useful as an 'is/was' indication for relative fuel efficiency.
    The computer values are off by at least 3-percent.
    If you've changed wheel/tires then you're going to see a change in your fuel efficiency. That change will be reflected more or less as inaccurately by the MDF whether or not you 'reset the computer.'
    If I understand the ECU's role in dolling out gas to each of the four cylinders, I'm not sure what resetting it will accomplish other than to erase the information stored from the 'summer gas' use history.
    The only 'learning' that happens from what I remember is the DTE (distance to empty) guestimations which are updated by historical fuel efficiency guestimations.
    Either way, your car's 'real world' fuel efficiencies are not going to be affected by resetting the ECU if I understand life in Priuses correctly....whether or not your local fuel supplier has started diddling with your local formula.
    Does this happen on a specific date in Caly?
    Do they drain the tanks first or is the summer gas allowed to mix with the winter gas briefly?
    Winter versus Summer blends in the south east must not be that big a deal, because I never hear it discussed other than in this forum.....but my tank-to-tank averages in winter change more from temperature variations than fuel blends - and even then not by that much.
    Spooled likes this.
  6. Spooled
    Spooled Member
    142
    25
    Concord, CA
    I too wonder if there i a "day" they change the formula, I have been meeting a lot fo refinery workers from socal lately, up in the bay doing a '"turnaround'" maybe thats it?
    Raytheeagle likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Turn around is just an industry term for shutdown.
    They do a lot of repairs as downtime is $$$.
    I know the labor pool is thin up here as the turnarounds are happening.
    Not related to answer you question I would say though.
  8. bisco
    49,441
    there must be a required date in the law, but who knows when it gets to a gas station?
    #8 bisco, Nov 16, 2018
  9. Spooled
    Spooled Member
    142
    25
    Concord, CA
    There should be a way to test it. Will return
  10. Spooled
    Spooled Member
    142
    25
    Concord, CA
    Boom! june 1 and sept 15
    We know that gas prices go up during the summer, generally around Memorial Day, but when do companies start producing these different summer fuels? The EPA defines April to June as the "transition season" for fuel production [Source: EPA]. Refineries switch over to summer-blend production in March and April [Source: EPA]. Gas stations have by June 1 to switch to selling summer-grade gas, while terminals and other facilities "upstream" from pumping stations have to switch by May 1 [Source: EPA]. Following the summer driving season, companies switch back to winter blends beginning in September, with the first winter increase in RVP allowance occurring on Sep. 15.
