Winter is coming
Discussion in 'Gen 4 Prius Main Forum' started by Mithrandrost, Nov 9, 2019.
  1. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
  2. Mendel Leisk
    41,925
    Yo:
    This works with Corolla rims, with the hub spec hub opening and raised lip (p/n 42611-02471, and similar). A 2" ABS end cap is slightly loose, you need push on some sort of rubber band first to fill the gap and keep it secure. Bicycle inner tube sections work.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    No PIP rims yet:whistle:?
    Thought the Steelies were done and you had to get new tires ;).
    But maybe one more winter(y).
  4. Mendel Leisk
    41,925
    This is more-n-likely just my eyes playing tricks, but now I've gotta ask: the tapered end of those nuts is facing inward? It should be.
    One more year. (y) Glacial pace, I know...
    alanclarkeau and Raytheeagle like this.
  5. bisco
    52,401
    winter? 20 here this morning :cry:
    Raytheeagle likes this.
  6. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    I’m heading to Iowa Monday where it’ll be 20 for a high and low single digits at night:eek:.
    I wish travel to that neck of the woods would happen at a different part of the year(y).
  7. bisco
    52,401
    yep, like business people here who have conventions in florida in july because its cheap (n)
  8. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    Good eye, Mendel. The nuts were not put on the right way. This has now been corrected. Next time I am near a mirror I will give the mechanic a piece of my mind
  9. Mendel Leisk
    41,925
    The close tolerance hub opening likely saved your bacon. (y)
    alanclarkeau likes this.
  10. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
  11. Mendel Leisk
    41,925
    Plus 9C here, low of 7C tonight. Ready a wee bit early, lol.
  12. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Threw some Amazon hubcaps on my Winter tires this time around. MVIMG_20191110_141817.jpg
  13. Chris Wolfgram
    Chris Wolfgram Active Member
    422
    169
    Sacramento CA
    2019 Prius
    Man I don't know how you guys handle that cr@p. Sacramento has days in the 40's. Sometimes in the upper 20's or 30's on a cold night, and that's way too cold for comfort. If I can't be comfortable in shorts and a tank top, it's too cold.
    We will probably be forced out by taxes and lame politics one day (our Governor is an idiot) but when that happens, we are heading for the desert !
  14. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    Ice pellets followed by snow today. Overall, the Prius handles well in this weather. IMG_20191201_164414_799.jpeg
