winter is gas de-icer advisable in tank?
Discussion in 'Gen 2 Prius Main Forum' started by aspens3, Oct 16, 2011.
  1. aspens3
    aspens3 Junior Member
    25
    Alaska
    Is the gas tank in the '07 Prius a plastic bladder? In the Toyota truck, I use a bottle of Heet (brand), an alcohol de-icer when the temperatures freeze, thaw, freeze. My question is about whether or not to use the product in a Prius.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It's not advisable to use in the Gen II Prius. You probably won't have a problem with ice in the Prius tank.
  3. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Many of us commonly use de-icer in our tanks, aka ethanol. Here in Minnesota, it's been that way for about 20 winters now and Prius have worked just fine. Adding Heet to non-blended gas would likely work fine too.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    If your fuel has ethyl alcohol in it (and it does) you don't need to add "deicer". Most deicers are isopropyl alcohol, some even use methyl hydrate. Neither are good for the car. Stick with ethyl alcohol (ethanol e10 fuel).
