Winter tires, Prius V five from Lexus ES 350
Discussion in 'Prius v Main Forum' started by dyun1dyun1, Aug 4, 2019.
  1. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    Severn, MD and Boone NC
    2017 Prius v wagon
    Found these wheels with 215/55/17. I assume that I won’t be able to drive with this size tire, but will the rims fit the stock 205/50/17 for my Prius?
    For $300, I wanted to put some winter tires.
    Thanks in advance!
    2017 Prius V Five | 2010 Volvo XC 90 3.2
  2. Mendel Leisk
    40,584
    If they're compatible I'd be inclined to swap them for the OEM (use the OEM for snows); they look sweet.
    #2 Mendel Leisk, Aug 4, 2019
    dyun1dyun1 likes this.
  3. Air_Boss
    Air_Boss Senior Member
    4,140
    1,154
    New Yawk
    The size and lug pattern are right (4.5”/114.3mm). No idea on the backspacing. We run 225/50R17 tires on our v Five, so size-wise, these should be compatible. Have to check the speedo correction factor.
  4. Offline
    Offline Active Member
    644
    236
    Lenexa, Kansas
    The Wheels and Caps website doesn't show an offset for the 17" Prius v wheels but it's probably the same as for the 16" Prius v wheels which it says is 39mm. It shows the offset for those Lexus ES wheels as being 40mm so they should work fine.
    If I had a do-over, I would buy the 16" Prius v wheels for winter use and buy wheel centers for them on eBay instead of buying 16" steel wheels and hubcaps. Regardless, there is a better selection of winter tires at a lower cost in 205/60-16 than in 215/50-17. 16" wheels also provide a cushier ride over rougher winter roads.
    Wheels and Caps is currently selling refurbished OEM 16" Prius v wheels for $134.67:
    aluminum-16x65-wheel-rim-69600
    The refurbished OEM wheels I bought from Wheels and Caps for our Sienna in 2014 were absolutely like new and still are in excellent condition after five winters.
  5. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    2017 Prius v wagon
    Going to check them out today. Does $300 sounds like a fair price?
  6. Air_Boss
    4,140
    1,154
    New Yawk
    Just remember they are seven inch wide rims, so don't expect to put narrow section skins on them, as some do with winter tires.
  7. Mendel Leisk
    40,584
    Use narrower, smaller diameter rims (with appropriate snow tires) for winter, and the wider, dressier rim for all seasons.
    I'm thinking the potential purchase rims are head-and-shoulders above the OEM's for looks.
    Can you get 16" OEM's on some level? Or a steel Camry rim? Something like that I would use for snows, with appropriate taller/narrower snow tire.
  8. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    2017 Prius v wagon
    Can you explain?
  9. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    2017 Prius v wagon
    Meaning 50 sidewalls?
  10. Air_Boss
    4,140
    1,154
    New Yawk
    No, meaning narrower than the OEM section width 205s, which many people do with winter tires (but I don’t).
    Raytheeagle and dyun1dyun1 like this.
  11. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    2017 Prius v wagon
    My wife bought the latest tires on the car which were 205/50/17. But looking up the correct stock, she should of bought 215/50/17. I wonder what happened there?
  12. Air_Boss
    4,140
    1,154
    New Yawk
    Tire guy offered what he had in stock?
  13. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    2017 Prius v wagon
    I just put them on as my winter tires, but didn’t buy the winter tires yet. The car drives better with these rims. Not sure about mpg yet. But I am going to take your advice and leave them for my all season wheels. And turn my Oem rims as winter.
  14. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    2017 Prius v wagon
    scona and Mendel Leisk like this.
