Winter tires PSI
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ricomtl, Nov 7, 2015.
  1. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I just got my 17" OEM mags swapped for 16" steel wheels and Michelin X-ICE 3 tires for the winter. I had them installed at my local Costco.
    Is it normal that front tires were inflated at 35 and rear 33? Should I increase it or just leave it as it? Just curious!
    Hope these tires are worth the money! :)
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    I'd sure be increasing that. Cold weather is bad enough, but with those pressures you'll be pretty unhappy with MPG.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,984
    4,729
    Texas Hill Country
    The standard pressures are listed on the drivers side door jam.
  4. fuzzy1
    10,174
    But his door jamb label is likely to show recommended pressure for only the 17" OEM wheels that came on his trim, not for smaller sizes such as he just put on and are common on other trims.
  5. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    42/40 works well in winter west Michigan
    ricomtl likes this.
  6. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I just read the door jam sticker and it does read 35-33... I just got the car 3 months ago and never really paid attention to the original 17" tire pressure. It looks like Costco used the safest PSI...
    I guess I could increase it, however I'd have to go back at Costco as they used nitrogen.
  7. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    I go to Costco too, but have wondered about topping up my tire pressure with standard air in-between visits. I can't imagine that it matters that much. Anyone know otherwise?
  8. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Costco won't go over manufacturer specs, adding air contaminates the helium, but if you want 42-40, which you do, you do what you gotta do, bo-bo
    ricomtl likes this.
  9. fuzzy1
    10,174
    Besides cost (for places that charge for it, not at Costco), this is the other significant downside to nitrogen: people reluctant to perform regular top-offs or pressure increases with regular air, thus possibly running lower pressure for a while than if they didn't have nitrogen.
    Go ahead, add regular air if nitrogen is not immediately available. The nitrogen 'benefit' is mostly hype, and regular air is almost 80% nitrogen anyway. Any downside to the 21% oxygen coming in with regular air is minuscule compared to the costs of running low tire pressure.
    CR94 and ricomtl like this.
  10. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I haven't had the chance to add more air at this point (busy week at work1), but I I had a call with the dealer to go over a few issues with my account, and they said that increasing to 42-40 decreases the overall performance of winter tires and will have less traction.He said their dealership has a strict policy of not going over 35-33 when installing winter tires on a Prius v.
    Why do they make it sound so serious while everyone here is cheering for more pressure!?
  11. Mendel Leisk
    38,738
    The sticker shows pressures for all the tire sizes that come with the car. Have a look at yours.
  12. fuzzy1
    10,174
    Mine shows pressures only for 15" main wheels and the 16" spare. Nothing for the 17" wheels on another trim.
    But half the label is in French, even though that isn't one of the top dozen languages spoken here. :) (Spanish, Korean, Mandarin, Japanese, Russian, Arabic, Farsi, Somali, Hindi, Tagalog, Romanian, etc., are all more common.)
  13. Mendel Leisk
    38,738
    Ok, stand corrected. Sorry for getting snippy.
    We've got the 17" OEMs, and the label shows both 15" and 17" pressures. Could be a Canadian thing too.
  14. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    I meant to ask about this. I put the Blizzak MS80s on steels for my first winter in Denver. I run 42/40 on my all seasons, but snow/winter tires are made of a softer compound so decided to run them at 38/36 psi...just guessing as I never had snow tires. Feedback on pressures from people that actually drive their Prius on 15" snow tires "in the snow A LOT" is what I seek...as it applies to traction, not mpg.
  15. fuzzy1
    10,174
    I was going to call it a Yankee thing, we have to be different than the Rest Of World. And with a much larger market, we could easier justify the costs of designing / ordering / stocking multiple labels. Though it that were really true, our labels wouldn't include unAmerican things such as French and kPa's. :)
    I don't recall if my 2010 was the same as your 2010 or as my 2012.
    'Everyone' here is a not actually everyone, just a strong majority, and speaking only to MPG and treadlife.
    For winter performance and wet traction, the opinions are much more varied, I wouldn't call it a consensus. You will have to make your own judgement which faction to follow. Many dealerships will match your dealership's view, and we don't know if they are really technically correct or just doing CYA for liability reasons.
    Both my Prii were delivered with 39-40 psi on their OEM A/S tires, the ocean shipping pressure. They were not reduced during dealer prep. I didn't ask about winter tires. My independent Subaru shop goes about 3 psi higher on all tires than door labels by default, which they feel is a better overall compromise between the competing goals (comfort, mpg, treadlife, traction). And they have no qualms about leaving higher pressures be if the customer arrives with such.
    #15 fuzzy1, Nov 11, 2015
    ricomtl likes this.
  16. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Just went back to Costco to increase PSI to 42/40 for my new Michelin X-Ice III.
    Will see how MPG goes going forward.
    Thanks for all of your feedback!
