Wiper blade refills
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mig1980, Jan 18, 2019.
  1. mig1980
    mig1980 Junior Member
    63
    El Dorado Hills, CA
    Good day everyone. I have been looking online for a while now in search of wiper blade refills for my two front wipers. I was able the remove the current blades and notice that they have a notch at the end of the blade on the rubber to secure it on the wiper blade casing.
    Any idea if there are refills that work the same?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Just get the generic trick blades they work better
  3. mig1980
    63
    El Dorado Hills, CA
    Can you point me to the ones you bare referring to? I purchased some Trico blades a while back and they are garbage (they fall off and don't clip on very well).
  4. Eodguy
    Eodguy Junior Member
    Seattle
    Crap i can't seem to post the links, I tried 3 different ways. Search amazon for.
    85214-30390 Passenger side
    85214-68020 Drivers side
    85214-0E050 Rear
    There ya go direct Toyota replacement refills. Easy to install to the factory wiper blades has the notch to hold them in place.
    #4 Eodguy, Jan 18, 2019
    minkus likes this.
  5. Mendel Leisk
    38,647
    Ask at a dealership parts department?
  6. NewHybridOwner
    NewHybridOwner Active Member
    607
    282
    W. Michigan
    I just asked at the local stealership parts dept. and got quoted $19.99 for a whole new wiper blade; they don't sell refills any more.
    I checked at parts.toyota.com: they show 85214-68020 as being for models up to 2014 but "could not confirm fitment" for a 2015 model. I have the Denso wiper blades that I bought on Amazon, but the rubber hasn't lasted a year yet: it wipes OK on the"upstroke" but then leaves a trail of tiny droplets on the "return stroke."
    pingd likes this.
  7. fuzzy1
    10,150
    I.e. a form of forced upsell.
    CR94 and pingd like this.
  8. Mendel Leisk
    38,647
  9. NewHybridOwner
    607
    282
    W. Michigan
  10. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    I bought genuine Toyota OE refills through Amazon, only to find they do not fit the new genuine Toyota blades the dealership installed before I bought the car CPO. The dealer blades require narrower refills like those in other recent aftermarket blades.
    So I bought Walmart blades, which work well so far. I think they're uglier than the dealer blades, though.
  11. Siward
    Siward Active Member
    296
    124
    Toronto
    I bought Kawoo hybrid frame wiper inserts from aliexpress. They are about $1 to $2.20 USD each. The rubbers fit directly on the OEM blade with the notch at the end.
    These are the cheapest wipers inserts I have ever purchased in my life. The cheap inserts worked well in removing water in the rain, but they squeaked because the rubber isn't as soft. The squeaking eventually went away after 3-4 months of use. They last pretty long too as I still don't need to replace them yet after 2 years.
    minkus and CR94 like this.
  12. NewHybridOwner
    607
    282
    W. Michigan
    I think my guess is close: on another Web site (now forgotten) it showed the 85214-68020 as being for a 2014 Prius up to some specific date of manufacture, so it looks as though it was during the 2014 model year that they switched.
    I've ordered a 85214-68020 refill. It should be here tomorrow, and I'll report back whether it fits the Denso 161-3126 wiper.
    Frank_Prius_Boy and Mendel Leisk like this.
  13. NewHybridOwner
    607
    282
    W. Michigan
    I can confirm that the 85214-68020 refill (Amazon Item# B003FADK7C) is a perfect fit for the Denso 161-3126 "Designer" wiper blade (Amazon Item# B007WMFDUQ), which I understand is the same as the earlier OEM blades but without the Toyota name on it,
  14. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    Just bought refills at the dealer. Put them in wrong at first, as the curvature of the metal strips must face away from the windshield and the notches in the strips must line up with a bump on the inside of the groove in the rubber blade. See this instruction for further info.
    Purrius and minkus like this.
  15. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    I have silicon wipers, the wipe edges are tougher when cleaning harden crap on the windshield so they don't tear after months. But then again I don't have the wipers even installed to save more gas.
  16. Mendel Leisk
    38,647
    I think that attachment's one of my "babies", and when I posted it I railed about it not being a part of the Owner's Manual. Just like to rail some more, same subject...
  17. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    Also, NutzAboutBolts has a couple nice viddies on this, entitled "2010-2015 Toyota Prius How to replace the front wiper insert" and "2010-2015 Toyota Prius How to replace the rear wiper insert", respectively.
  18. Mendel Leisk
    38,647
    Be careful what you wish for too: our previous Civic Owner's Manual, had instructions for changing the wipers, but cocked it up: if you pushed/lifted as they said, nothing much happened, except you got a sore back.
    Oh also: whenever taking the blades off the arms, be really cognizant, that bladeless arm can thwack down on the windshield hard enough to crack it, so lay a rolled up coat or blanket over the "landing zone".
  19. Purrius
    Purrius Junior Member
    60
    16
    Northeastern US
    You're an absolute legend for sharing this pdf. Thank you so much!
