Wiper Blade Replacements/Refills
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iplug, May 13, 2015.
  1. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Coming up on the first time needing new wiper blades and wondering what the consensus is - should I go with wiper blade refills or replace the entire wiper blade?
    I noticed the original PiP wiper blades have aerodynamic coverings built into the unit, but most of the off-the-shelf replacement blade units are pretty clunky looking and not aerodynamic.
    Any recommendations would be appreciated.
  2. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    I would go with refills, if easily available. My PiP also has those aerodynamic ones, and refills are generally cheaper than all new blade assemblies. Unfortunately, my local Toyota dealer has stopped carrying the refills for some strange reason.
    Also, one set of nicer 3rd party ones I installed for my Gen II Prius actually blocked the windshield fluid spray partially. Very irritating.
    iplug likes this.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Refill insert made with silicone. Durable and quiet.
    iplug likes this.
  4. Okinawa
    Okinawa Senior Member
    1,333
    317
    Get the refills. I would buy them and have them installed at a Toyota dealer. You may luck out and they may not charge you for installation. They did not charge me anything to put mine on.
    iplug likes this.
  5. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It is easy to install. First time could be tricky but once you know, it is easy.
  6. Mendel Leisk
    40,583
    Maybe it's because ours is low mileage and garaged, but with manufacture date August 2009, and purchase (new) November 2010, were still using the original blades, and they seem fine.
    Sometimes it's windshield that develops a film, causes the blades to jitter and/or streak.
  7. Okinawa
    1,333
    317
    The dealer likes to tell you best to change them every 6 months. My car is garaged also and one year old. The wipers wipe well with no streaks. I'm going to just keep using them. I think they will last a long time.
  8. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    Where do you get these?
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  10. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    I changed all 3 at 4.5 Years 60000 miles with original Toyota inserts bought on eBay from Toyota parts dealer For 22 dollars.
