Wiper inserts vs Replacing Entire Blade
Discussion in 'Generation 1 Prius Discussion' started by jamesprius, Dec 26, 2024.
  1. jamesprius
    jamesprius Member
    142
    17
    San Jose, California
    2001 Prius
    I
    The rubber part of my blades came off.
    Never replaced wiper blades before.
    Does it make sense to get the inserts or replace the entire blades with generic ones?
    Looking at some of the inserts online, not sure if they will fit or not. A lot of the listings just say the inserts are "universal"
  2. ChapmanF
    17,119
    Toyota sells the replacement inserts for their blades, and they've been reported here to be good quality, and not expensive. They'll fit if you have the original blades.
    I have tended to replace my original blades with the jointless beam-type blades. I started doing that when we used to get winter weather here that would prevent jointed blades from bending at the joints. (There used to be "winter" jointed blades you could buy with ugly rubber boots to keep the joints from icing, but the jointless blades solve the same problem more elegantly.)
    On the other hand, we get very little of that kind of weather here anymore.
    jamesprius likes this.
  3. Trombone
    Trombone Active Member
    285
    100
    Allentown, Pennsylvania
    2002 Prius
    jamesprius and vvillovv like this.
  4. BiomedO1
    BiomedO1 Senior Member
    2,686
    1,437
    SacTown, Ca
    I replace the inserts, not the full blade. It's cheaper and less prone to skipping vs the non-OEM full blade replacement.
  5. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    Ended up changing just the inserts for some generic silicone ones. hopefully they last at least a few years.
    It was pretty difficult to release the blade from the metal u loop. There is a tiny latch that you have to push down (which barely moves) to loosen the plastic loop to unhook the housing.
