Wire connections for Eclipse BEC104 camera
Discussion in 'Gen 2 Prius Audio and Electronics' started by hawkjm73, Oct 16, 2005.
  1. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    For posterity,
    After getting info from lots of places online, I did some fiddling and my BEC104 camera is working with an RCA plug now. NOTE: This camera is 6V not 12V.
    Okay, the wiring for a BEC104 (not 104G) is
    Red = Power in - 6V+
    Yellow = Video signal Out - attach to the center conductor of an RCA
    plug
    Black = Ground - I'll use the vehicle ground
    White = Shield - attach to the outer shield conductor of an RCA plug
    I don't have it in the car yet, as my NTCS->RBG converter box has not
    yet arrived, but I can get a decent picture on my TV. (Hint: there
    is a good chance one of the orphan power cubes lying around the house
    has a 6VDC output. Lots easier then hauling a TV out to the car or a
    car battery to the TV for temporary system checks)
    So, for those who insist on the Eclipse camera but cannot aquire the
    104G, the plain 104 will definetly work.
  2. 200Volts
    200Volts Member
    435
    45
    Northern CA
    Which converter did you order?
  3. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    I'm getting a Vidtoyo1 by Soundgate. It is video only and has two video ports. It dosen't interact with the touch screen buttons, but I didn't want to do the indefinite wait for the Coastal model. It does have wiring to automajically switch to the rear view camera input when in reverse. It says it will switch into other video sources whenever it detects them I got mine off Ebay, as I could not find any online store that actually had any in stock for less then $375 or so. I just got word it shipped today, so hopefully by this weekend, I can report on the final install.
