Wire Diagram
Discussion in 'The File Library' started by drjake, Dec 18, 2011.
  1. drjake
    drjake New Member
    PA
    Here is a good Gen II wiring diagram lets see some good mods
    gdanner, LukUsc, w2co and 1 other person like this.
  2. Kmack
    Kmack New Member
    Ontario
    Full Color Schematics etc. for 2004-2005 Gen II. Found elsewhere on the internet circa 2007. I make no claim to ownership of this information - no copyrights or other info were included in the original download.
    I found it easier to look at than the Toyota service manuals.
    Enjoy!
    LukUsc, dodgese and Rockheady like this.
  3. MrTea
    MrTea Junior Member
    29
    Topeka, KS
    Anyone has Gen III (2012) wiring diagram?
    Sappy likes this.
  4. SamelCamel
    SamelCamel New Member
    60
    Kansas
  5. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    You're in the Gen II Forum...
  6. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    So is there a file library for gen III then?? I don't see one listed and only found this one.
    #6 DaneH5, Sep 6, 2014
    GG707 likes this.
  7. gandG
    gandG New Member
    28
    I found the diagram in another Priuschat forum. I wanted to set up a separate subforum but did not see how. If I recall, look in the site
    we0h/Prius n that is we{zero}h/Prius [this would be a full URL but as a newbie I am not allowed to post messages with actual URLs yet... :-(
  8. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    What is it?
  9. Mat Salleh
    Mat Salleh New Member
    United States
    FANTASTIC. Used the diagram to pinpoint what was blowing the GAUGE fuse on my '05 gen2. Turns out it was the cheap door window master switch cluster I purchased on Amazon. Thank you @drjake!
    dpower and JahT like this.
  10. gdanner
    gdanner Member
    134
    51
    Central Illinois
    "prius wiring.pdf" is missing pages 66-69 which describe the "Power Source" wiring connections.
    Otherwise it is complete.
    Has anyone seen the missing pages?
  11. dolj
    dolj Senior Member
    8,479
    4,303
    Wellington, New Zealand
    Have you compared it to the one in this thread? The file is larger, so hopefully it contains the missing pages.
  12. gdanner
    gdanner Member
    134
    51
    Central Illinois
    I have that file, but it is for 2006 model year. There are several wiring differences between 2004-2005 vs. 2006. Some parts, such as the engine compartment fuse block, are totally different.
    Although the 2006 wiring diagram is helpful, it would be even better to have a complete 2004-2005 wiring diagram with no missing pages.
    I also downloaded "Prius wiring.zip" from this thread. It unzips into 101 individual .jpg files. None of them look like the diagrams in either the 2004-2005 or 2006 versions of "prius wiring.pdf" Also these .jpg files aren't very high resolution. Text labels in them are difficult to read.
    As stated in my previous post, the only item missing from the 2004-2005 "prius wiring.pdf" (posted in this thread) is pages 66-69.
    I'm searching for the missing pages from the 2004-2005 wiring diagram because my 2005 Prius suddenly developed a really odd problem. (I think I should start a new topic to discuss this in greater detail.)
    My symptoms:
    Following items suddenly stopped working:
    • All interior lights (ceiling, lower doors, rear hatch area)
    • Wireless smart key fob feature
    • Clock
    • Radio/CD player
    However, many other items still work:
    • Door locks respond to inserting the physical key into the external drivers side door lock: Turning key clockwise unlocks the drivers door. Turning it clockwise a second time unlocks all doors and rear hatch. Turning it counterclockwise locks all doors and rear hatch.
    • Rear hatch can be opened (when unlocked)
    • Emergency blinker
    • Light switch
    Plus, all of the following items work when smart key fob is inserted into dash slot and "IGN" mode is selected by the power button:
    • Combo meter
    • Multifunction display (however, radio CD player and map feature still do not work)
    • "Door open" icon in combo meter works. It lights up when a door is open, turns off when all doors are closed
    • All windows go up and down
    • Side mirror controls
    • Turn signals
    • Power button cycles normally through its standard operational modes (off, acc, ign, and back to off). Note: I am not attempting to put the car into "ready mode" because my HV battery is out of the car right now for busbar cleaning and replacement of 2 faulty NiMH blades. However, all 12V powered functions were working fine without the HV battery. Then the above symptoms began. I don't think the missing HV battery is causing my problem.
    So far I have confirmed that my problem relates to the 12V circuit labeled "DOME."
    Some devices fed from the "DOME" circuit are no longer receiving 12V.
    This circuit is "always-on" regardless of the state of the power button.
    The DOME circuit has a 15A fuse under the hood. This fuse is good. It has never blown.
    Under the dash the "DOME" circuit splits into feeding a whole bunch of different sub-circuits.
    I'm now attempting to locate the open circuit under the dash. This is where a complete wiring diagram would be helpful.
  13. 2genowner
    2genowner New Member
    16
    Rhode Island
    Did you find a solution? I have a 2007 that seems to have the same issue where sks system is not working. maybe i can find what wires are what in the certification ecu and determine if it is not getting power
  14. gdanner
    gdanner Member
    134
    51
    Central Illinois
    Don't forget to check the SKS button under the steering wheel
    (It's actually a bit to the left of the steering wheel near the lower edge of the dash panel).
    It works backwards compared to typical power buttons where "on" (or "active") corresponds to the position where the button is depressed.
    But in the Prius, releasing the button enables the wireless key feature.
    Putting the button into the depressed position (button flush with panel) disables all remote key functions.
    Note that switching off SKS reduces drain on 12V battery. This is useful if the car is going to be parked for weeks or longer.
  15. dolj
    dolj Senior Member
    8,479
    4,303
    I doesn't work backwards; it is the notion that the button switches SKS on/off that is backwards, when in fact the function is to disable the SKS (ON) or not disable (OFF). When understood this way IN is SKS disable ON and OUT is SKS disable OFF, just like you said here:
    Or you could have said, "Note that disabling SKS reduces drain on 12V battery." to be consistant with the first point mentioned above.
    gdanner likes this.
