Wire harness.
Discussion in 'Prius c Accessories and Modifications' started by tgpii, Jun 15, 2014.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    I can not find a plug in play wire harness for a prius C. I seen tons of stuff online for a prius wire harness but nothing for a prius C. Anyone seen anything online for a prius C or how to hook up a universal wire harness? I know there are already forums on this, however since priuschat changed the page layout I can't find my way around. Thanks!
    jdmprius likes this.
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i am not sure what harness you are looking for. please explain? or am i missing something
  3. xliderider
    xliderider Senior Member
    7,874
    3,117
    Honolulu, HI
    Exactly. Trailer harness, HID relay harness? :confused:
    SCH-I535
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Yep. Can't help unless we know what type of harness it looking for.
    VS980 4G ?
  5. Mr.Electric
    Mr.Electric Member
    287
    102
    San Francisco
    I would guess the op means radio wiring harness.
  6. tgpii
    tgpii Member
    382
    63
    trailer harness
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    You are REALLY going to try and pull a trailer with a C ??
    I'm pretty sure that is NOT recommended........and might explain why there is no harness available.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    If the plug on the taillights is the same as the reg prius, then I would just use that.
    Do the g really make a hitch for the C?
    VS980 4G ?
    tgpii likes this.
  9. tgpii
    tgpii Member
    382
    63
    They make hitches for smart four two. Anyways they make a prius C hitch for bikes racks.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    It looks like the plugs are the same however u may need to relocate the wires in the connector. I would buy 1 & give it a shot. If it doesn't fit, return it.....only thing u'll be out is S&H
    VS980 4G ?
  11. Easy Rider
    982
    210
    N. Central Florida
    Check their return policy BEFORE you buy.
    Some (many) places do NOT allow returns on electrical parts.
    sfv41901 likes this.
  12. tgpii
    tgpii Member
    382
    63
    How hard is it to buy a universal brake light/trailer/toying wire harness splice/slice the wires and install it?
  13. xliderider
    7,874
    3,117
    Honolulu, HI
    Shouldn't be too hard once you gain access to the wiring by removing all the necessary trim panels, and figure out which wire is which. Then figure a path for the harness to exit the car.
    SCH-I535
  14. tgpii
    tgpii Member
    382
    63
    How much does a wire harness for towing cost? (Universal) What are the differences on it? How much would a shop charge to install it?
    How much is a hitch for a prius C?
  15. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    If you only want a hitch for a bike rack, why do you need a light adapter? Bike racks don't have lights.
    SPH-L300 ?
  16. scrull
    scrull Junior Member
    36
    24
    Charlotte, North Carolina
    For a receiver hitch, here you go:
    Trailer Hitch for 2012 Toyota Prius c | etrailer.com
    That has a 1 & 1/2" receiver so you would need to find a bike rack that allows for that size. Something like this would work:
    You don't need any lights for a bike hitch. As far as towing, I wouldn't pull anything on the C other than this. You have <100 HP.
  17. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Etrailer 119147KIT
    iPad ?
  18. tgpii
    tgpii Member
    382
    63
    You don't need a trailer wire harness for a bike rack. Just figure if I am going to put a hitch on, I might as well put a trailer wire harness to.
  19. tgpii
    tgpii Member
    382
    63
    What is that?
  20. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Etrailer.com lists that as the trailer wire harness you requested info on. It usually connects the the tail lights to provide lighting function to trailers, etc.
    SCH-R530M ?
