Wire tap for subs
Discussion in 'Gen 3 Prius Audio and Electronics' started by tecmo04, Apr 8, 2014.
  1. tecmo04
    tecmo04 Junior Member
    detroit
    Why is it required to tap the left and right speaker for the sub output? Don't subs run off a mono signal? I currently tapped into the driver side wires behind the seatbelt and split them. Before I go through the Hassle of the other side I was just curious!
    Thanks
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    The bass isn't always evenly split between the L and R channels. Combining the two channels, even though the output is monaural is the solution.
    Remember also, that low frequencies are non directional, so it can be monaural. ;)
    SCH-I535
