Wireless charging of an IPhone 13
Discussion in 'Gen 5 Prius Technical Discussion' started by 2023priuspete, Sep 18, 2023.
  1. 2023priuspete
    2023priuspete New Member
    Wake Forest NC
    2023 Prius
    I love the connection between my IPhone 13 and my 2023 XLE, but the wireless charging feature doesn’t seem to work no matter what I do. It starts out blinking 3 times (manual says phone placed incorrectly or other error). My iPhone is in an otter box so I thought maybe it was too thick even though other wireless chargers have worked. But even out of the case the best I can ever do even with lots of moving the phone forward and back in the slot is a green light and the phone never shows as charging.
    Has anyone else had a similar experience and been able to get the charger to work?
  2. aforkosh
    aforkosh Active Member
    413
    262
    Oakland, CA
    2023 Prius
    I've had the same experience with an iPhone 14 pro in an Apple Clear Magsafe case. I now run a black charging cable from the USB-C port in the console box along one of the grooves to the phone slot. It's black to be almost invisible against the black plastic.
    2023priuspete likes this.
  3. HacksawMark
    HacksawMark Active Member
    442
    287
    Oregon
    2023 Prius Prime
    XSE
    I had an Otter Box Defender on my iPhone 12 Max Pro and it would not charge, all I got was the flashing amber light. I took it out of the case and it charged right up. Not wanting to go without a case, I now use a case by BodyGuardz and it charges fine (steady amber).
  4. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    I have a UAG real carbon case on my 13 Pro Max. The light on the charger will show orange but the lightening bolt won’t show up on my phone with the case on in the wireless charger.
    On my long drive back from the dealer I simply popped off the case slid the phone in and it worked perfectly fine. Yeah the phone got warm but not dangerously hot like some people are saying. Not a fast charger but it def charged up the phone and ran apple car play for a couple hundred miles no issue.
    FYI, make sure you push the tiny charger on button in the front of the phone slot and make sure the led turns green. If not no charging no matter what you do.
  5. JDS4
    JDS4 Junior Member
    35
    24
    Oregon
    2023 Prius Prime
    XSE
    Which model case did you get ? TIA
  6. 2023priuspete
    Wake Forest NC
    2023 Prius
    Otter box. I think that’s the issue
  7. 2023priuspete
    Wake Forest NC
    2023 Prius
    Thanks. I’ll look for a bodyguards. I have an otter box on it now.
  8. HacksawMark
    442
    287
    Oregon
    2023 Prius Prime
    XSE
    I got the Ace Pro.
  9. JDS4
    JDS4 Junior Member
    35
    24
    Oregon
    2023 Prius Prime
    XSE
    I got that. I am wondering which bodyguardz he got.
  10. 2023priuspete
    Wake Forest NC
    2023 Prius
    I’m going to try a defender with MagSafe. If it works, great! If not, I’ll return it for a refund and take my phone out of my old cover when I want to charge. May be a hassle but I will work !!
  11. William Boren
    William Boren Junior Member
    Houston TX
    2023 Prius
    I'm having the same issue with my 13 Pro Max in a MagSafe compatible case from Casetify. I have tried 3 other slim-style cases with no luck. My sister's 12 Pro charges fine in a cheap Amazon case (I ordered the exact same one and it didnt work on mine) and my boyfriend's Galaxy S23 charges through an Otterbox defender. What gives? I reported my issue to Apple, should I report it to the dealer as well?
  12. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Just realized it literally takes less than a few seconds to pop off my UAG real carbon case and it charges perfect every time. So that’s what I will be doing and using the wireless slot charger if I’m commuting or on a road trip. Will prob still pick up a USB - C Cable for faster charging but the slot charger is convenient and I found on my 1.45 hr drive the other day I gained roughly 20-25% battery. Phone was warm not hot.
    Edit: I used to only use Otterbox defender cases and those beasts would be a solid no for just poppin them off unless a looong road trip as they are a total pain in the butt to remove.
    daisy555 and HacksawMark like this.
  13. HacksawMark
    442
    287
    Oregon
    2023 Prius Prime
    XSE
    Same here because I like carrying my iPhone Pro Max in my back pocket. I could sit on that all day and it wouldn't break. It would charge up in my F 150 but it would be almost too hot to handle because of the case. Wouldn't charge at all in the Prime. Switching to the Bodyguardz did the trick. It warms up but doesn't get overly hot.
  14. JDS4
    JDS4 Junior Member
    35
    24
    Oregon
    2023 Prius Prime
    XSE
    I’ve been looking at the Bodyguardz. Which model did you get that works with the charger?
    HacksawMark likes this.
  15. HacksawMark
    442
    287
    Oregon
    2023 Prius Prime
    XSE
    I got the Ace Pro. It works great for charging.
  16. planetarian
    planetarian Member
    75
    73
    Kentucky
    2023 Prius
    XLE AWD-e
    I have a Galaxy Z Fold 3, and a Razer Phone 2. I've tried it with both phones. the RP2 never works with it, and the Fold 3 only works sometimes. 4800 miles in and I've yet to find any consistent way to get my Fold 3 to charge from it. This is annoying because it's one of the features I looked forward to having with the XLE.
  17. JDS4
    JDS4 Junior Member
    35
    24
    Oregon
    2023 Prius Prime
    XSE
    I got the Bodyguardz Ace Pro per HacksawMike and it does charge a lot better. It will still still cause the light to flash on occasion but it works most of the time. Much better than the other three cases I tried. Thank you @HacksawMark
  18. EricA1000
    EricA1000 New Member
    Colorado
    XSE Premium
    I was having the same problem charging my iPhone 13 Mini wirelessly in my 2023 Prius Prime. It would not charge with or without the case. Today I tried again put placed the phone as far right as possible up against the right wall when placing it in the charger and it worked! It actually worked with the case. Try loading the phone to the right fully against the right wall. FYI: the phone does get a bit warm when charging
    daisy555 likes this.
  19. I Throw 99
    I Throw 99 New Member
    28
    2023 Prius
    XLE AWD-e
    Strangely, my wireless charger started working with the case on this morning. I haven't actually tried it for a while, and had just been plugging it in. But my old, original case was in bad shape, so I replaced it with an identical case (the apple leather case), and it suddenly worked. I also tried a skinny otter box case as well, but it didn't work with that case either. While I am happy that it now works, I'll probably still just use the cable for any drive longer than a quick trip to the store, since it still gets hot.
