Wireless phone charger. Leave on?
Discussion in 'Prime Main Forum (2017-2022)' started by mveras1972, May 23, 2019.
  1. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I have a 2017 Prius Prime Advanced. I’m curious about the built-in wireless charger. How much power does it consume if left on all the time? I’m not charging my phone all the time, so there could be times when the charger is just turned on but my phone is not in the charger. Should I worry about turning it off when not charging my phone so my EV batteries last longer per charge? Also, is it preferable to use a USB cable in terms of charging efficiency?
  2. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    The USB port is pretty anemic when it comes to charging.
    Do you lay metallic objects on the charging pad other than your phone?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    NO.....and maybe but not enough to worry about.
    Obsessing over insignificant details is not good for your health.
  4. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Does it even use power when not charging a phone? I gave up using both OEM remote charger and OEM USB port for charging my phone. They are sooo slow. I now use PD3.0 and QC3.0 63W 12V car charger. It takes less than 15 min to charge my phone from ~30% to full.
  5. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    It is preferable to use a USB cable connected to a good quality 12V power adapter (I like the 2-port Anker models). The existing USB port is woefully low on current. My iPhone 7 Plus will discharge when plugged into the existing USB port on the car, so it never plugs in there. The only device I have found that will keep a charge on that port is an older hard-drive iPod.
    Only if you are concerned about the 2 inch EV range difference.
  6. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Im pretty sure it does not use the traction battery but it's not hard to just turn it off
  7. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    The Prime has no alternator, and when the car is in IGNITION ON, 12V DC loads are powered from the traction battery via a DC-DC converter under the hood. In EV mode, all power for the vehicle comes from the traction battery, including this (very small) load. When the car is off or in Accessory, 12V loads are powered from the 12V battery.
    When running the engine, the engine charges the traction battery and the traction battery continues to power the DC-DC converter. In this case, the original source of the power is the ICE, but the DC-DC inverter is always powered from the traction battery.
    #7 jb in NE, May 24, 2019
    mveras1972 and kevin.c like this.
