Wires connection of back-up camera to MFD !!!
Discussion in 'Gen 2 Prius Audio and Electronics' started by cozmisu, Oct 20, 2012.
  1. Tideland Prius
    16,623
    I wasn’t aware you could share conversations, I assume it’d give you an error. But yeah it’s broken for me as well.
  2. James Analytic
    362
    Michigan
    Did you ever determine what the equivalent to M15 is in the 2004-2005 model MFD's? I do not see on the 2004 Service Manual online. Connection appears to be the same, though not certain being I do not see in the Wiring Diagram anywhere or in the vehicle harness. Guessing only NAV related that is on the 2006-2009 NAV models with a TX4- and TX4+ requirement.
    Neat to test a 86110-47260 without the M14 connection in a 2004, just did that today earlier, though I do see now how to apparently interface and repin between the two if needed M14 connectors. Would only be the 86110-47071 model 2004-2005's if one wanted the hands free Bluetooth and NAV system operational.
    So far, I have not found a working hands free Bluetooth or factory installed rear view camera 2004-2005. Wondering what fails on those hands free systems as mine appears to pair Bluetooth wise, though fails to have functional audio?
    Wound up hot air gun removing an M13 female connector off a broken 04-05 model to make an adapter with an 06-09 M13 male pigtail for some lady.
    Wondering if way to share the conversation as well?
    #182 James Analytic, Feb 26, 2026
