Wiring chart
Discussion in 'Prius v Audio and Electronics' started by djarmy2004, Jul 17, 2018.
  1. djarmy2004
    djarmy2004 Junior Member
    17
    Dale, Indiana
    ozjimjam and bisco like this.
    49,371
    thank you!(y)
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    It actually says "Prius v" - is that correct?
    Elektroingenieur likes this.
  4. Elektroingenieur
    2,515
    3,258
    Three Touring
    I think so; it’s definitely not for a fourth-generation liftback Prius.
    I checked the item called “Second 12 volts,” for example, which says to find a green wire on terminal 13 of a 36-position connector of the “dash fuse box” (presumably, the Instrument Panel Junction Block Assembly). That matches Toyota’s Electrical Wiring Diagram for the Prius v, which says that’s the 12-volt supply for the driver’s power seat. It’s totally wrong for a fourth-generation Prius, on which terminal 13 of the 36-position connector on the Instrument Panel Junction Block Assembly is a yellow wire for the left rear turn signal.
    The interactive EWDs for both models are available by subscription to techinfo.toyota.com. I strongly recommend these for anyone considering modifications, since summaries—like the one kindly shared in this thread—may not provide all the information needed to design a safe and reliable installation.
    Gas Mizer and alanclarkeau like this.
  5. ozjimjam
    ozjimjam Junior Member
    35
    17
    22
    australia
    2016 Prius v wagon
