Wiring Diagram For JBL Amplifier
Discussion in 'Gen 2 Prius Audio and Electronics' started by Dion, Jun 4, 2004.
  1. Dion
    Dion New Member
    128
    Jersey City, NJ
    Does anyone know where I can find the wiring diagram for the Amplifier located under front passenger seat in the premium JBL system? Thanks. :computer:
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Wiring on the outside or a schematic of the amp itself?
    The EWD for the 2004 Prius shows it's connectivity. $10/day at techinfo.toyota.com will allow you to grab it.
    The filenames of the files containing what you may want would be:
    052mdass.pdf (Multi–Display and Audio System with Separate Amplifier)
    or
    overalle.pdf (Overall Electrical Wiring Diagram)
    Using the "titles" for search terms may get you there the quickest.
    I'd post the files, however they are copyrighted by Toyota, and $10/day isn't a whole lot to grab a good portion of manuals costing many times that much.
    -Rick
  3. Mike N
    Mike N New Member
    55
    Los Angeles
    Are the repair and electrical manuals there for the downloading?
  4. Dion
    Dion New Member
    128
    Jersey City, NJ
    Yes. the repair and wiring manuals are there, but each section of the manuals (2-5 pages) is a separate PDF file. It will take you hours to download everything, because you can't download the entire manual at once, only a section at a time and rename each file because most have the same filename. It's still cheaper than the printed manuals. I know some people have reported downloading everything, but they are copyrighted.
  5. HTMLSpinnr
    5,339
    917
    251
    Once upon a time, they had directory indexing turned on at their webserver, and we were able to grab the whole 9 yards. However, those of us who discovered it also made it known on the boards, and they quickly closed it up :-/
    I have a legit copy downloaded, but I'm wondering if it hasn't since been updated.
    Using what I put above, you should be able to find what you need.
