wiring diagram for rear view mirror? power for dashcam
Discussion in 'Prime Main Forum (2017-2022)' started by ltlurker, Aug 18, 2023.
  1. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    does anyone have the wiring diagram for the rear view mirror? trying to tap the power for a usb dashcam but not sure which wire is the safest to use? thinking homelink??
    this is for a 2020 prius prime
    thanks much
  2. PriusCamper
    PriusCamper Senior Member
    12,023
    4,885
    Pacific Northwest, USA
    Back in my car stereo installer days we used a test light to poke the terminals or the wires to find a 12v signal... I doubt a dashcam would draw very many amps, but if in doubt you could wire up a light bulb that draws more amps than the dashcam to confirm.
    Also is this is a rearview mirror mounted daschcam? If so, which one did you buy? I've always wanted to buy one but get overwhelmed trying to figure out best quality/design for price?
  3. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    it should work but i just don't know what the voltage is for the rear mirror. if it's 5v then i don't even need a converter for the USB split
  4. sylvaing
    sylvaing Senior Member
    1,200
    507
    Maybe buy a multimeter? They're not that expensive and can be useful in many occasions.
  5. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    i have one but the wires are very small and would require a lot of work. i ended up getting this to avoid the hassle
  6. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    from am azon
    Dongar Dashcam Power Adapter (10-pin Type A) Compatible with Select Nissan, Frontier, Titan, Altima, Infiniti, Subaru, Toyota & more. Connects to Rearview Mirror, Built-In USB Power Source, EZ Install
    sylvaing likes this.
  7. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
  8. Chucky500
    Chucky500 New Member
    Sacramento, CA
    2018 Prius Prime
    I installed a FITCAMX (w/ rear camera) in our 2018 Prime. Worked out pretty well. Includes wiring adapter to hook into wiring loom near the car’s front camera. The only significant issue I’ve had is the card has to be reformatted every few days to avoid filling it up full, otherwise the files become corrupted - this is the case even with a better card than fitcam supplied, so I presume there is a firmware issue.
  9. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    to close the thread so others can find info. I ended up using the mirror power as tap. in the picture, there's a plug with 3 wires, green brown/black and brown on top. the green and brown/black are next to each other. the green the 12V load and only has power when car is on. I used that to split into a cig lighter to DIY a USB-A port. with that port, I was able to connect camera.
    it's a easy install since you don't have to remove dome light. The rear view mirror panel easily pulls off exposing the wires. the hardest part was testing all the ports to find a 12v that's only on when car is on.
  10. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    also to add, i used rear view mirror as that's the least destructive it seems. i didn't want to use the power to the range sensor and rear view mirror power seems fairly low risk to have some power sucked out
