Wiring for an EVSE
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by crewdog, Jan 9, 2012.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    Electricians at house today, among other things are wiring a 120v 15a GFI separate circuit for the EVSE.
    When I was talking with the guys, who are EVSE installers for Nissan Leaf EVSEs, that I had not decided if I was gonna install a 240v EVSE, they suggested, and I agreed, that since they had to run a wire anyway to unframed garage wall, it might as well be a thicker gauge to easily switch to 240v if i decide to in the future. All that would have to be done is to put in a 240v breaker in the panel, and appropriate socket.
    Maybe this would save some $ in the future in install costs.
    52,391
    seems like a good idea, from what gauge wire to what gauge wire and how long is the run? do you need 3 wires plus ground? how much more money do they want?
  3. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    No you need 2 wires plus ground (I wound up having to buy a 3 wire plus ground though because you CANNOT use the bare copper wire as your ground)... In my Voltec EVSE it was pretty straight forward. You have your 2 power, and then your return to ground back in your main panel. In my house the charger is only 15 feet away, so all supplies were less than $100 including conduit, 25ft of 10ga wire, and all the minor stuff.
    On the wiring also be sure it is the solid copper, and not the stranded. Depending on your amperage rating of your EVSE you may have to go bigger than 10gauge.. For the Volt it recommended 12 minumum, but I wanted to be on the safe side. That is just for 240V/15amp. It really is not to bad as long as you are either installing it outside near the main panel like I did, or you have a bare garage like the OP. Definately do your research though, and have it done by professionals/or the work inspected & signed off on by a master tech before connecting power. I did the later, and bought all the materials myself so I knew exactly what was going in/where it came from. Was about $150 for them to come by, inspect it, and hook it all up in the main panel. So around $300 after taxes for the install and another $490 for me for the L2 charger. Do not take any outrageous quotes you get (IE from SPX, or some of these other companies).. The locals are a lot freindlier, and a lot more eager to earn your business. Best of luck!
  4. crewdog
    493
    388
    Woodstock, GA
    they were going to use 14/3 for the 15a 120volt GFI outlet for the included evse, and went with 12/3, since i looked at the specs for the leviton evse and it said it drew 16 amps, and would have to be on a 20 amp 240 v breaker.
    The run is about 50 feet from panel to receptalcle.
  5. bisco
    52,391
    makes sense.
  6. mrbigh
    3,686
    699
    Long Island, NY
    What type of L2 EVSE had you purchased @ $490.00?
  7. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Sounds like the SPX Voltec unit for the Chevy Volt...
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I'd run two separate outlets and breakers, 110 and 220V. When the 220V EVSE costs $99 in a few years, you can plug it right in.
  9. Roadburner440
    316
    59
    Hampton, VA
    You are correct. I went to Lowes/Home Depot and looked at I think either a Columb charger, or whichever one if is they sell for $999 that was a white box with the almost Ipod like design/look to it. My main battle was even I paid $999 for a L2 charger that can charge at 30-50 amps the max the Volt will ever draw is 15a. So it would increase my cost for wiring, because I would need really beefy wiring as you must go off the chargers max capabilities, and not what the cars max charge rate is. So in the end for $490+tax (was I think $520 shipped, would have to look at the reciept) I saved $500, and got a charger that is a perfect fit for the car. The ONLY upside I see to getting one of the other chargers is they are UL approved, and the Volts is not for some reason. Then I got the free evaluation from SPX, and their estimate to do my install was almost $1400 (not including charger price). I found a local electric company that specializes in alternative energy (Dynamo for those of you in the Norfolk area). Extremely professional, and very helpful. I installed the charger where I wanted it. Hooked it all up, ran the wires/conduit and all inside the house to the wall under the main panel. Guy came and inspected all of it, checked inside the Voltec unit. We then closed it all up, and connected power. Have not had one issue with it, and it has been charging daily since December before Christmas. So if you go with a local install you can save a lot of money. I know Toyota is claiming to install the PiP's charger for $999, but something tells me that will not be correct for everyone. Especially for guys with long runs from their main panel, or if you need to put in a sub panel with its own ground. You could run well above $3000 in some of those cases if you go with the "approved installers." You are better off getting your own charger, and paying a local to install even if you don't buy the supplies. Cause he told me even if I had not bought my own supples it still would have been only $600-$700 for him to of completely done my install. Which would have still been under the original SPX estimate for the installation alone.
    To wrap it all up though I do not believe you guys really need a L2 charger, and you can really save yourselfs a lot of money and hassle.. I myself even with the Volt really do not "need" the L2 charger, BUT it takes a lot of power to pre-condition the car in cold areas. So since the Volt has an electric heater that the #1 reason I bought the L2 charger. I really think you guys can get away with using the charge cord that comes with it. The only secondary advantage to the L2 is that you don't have to worry about someone grabbing and stealing your charge cord overnight. Lastly the faster charge times, but your charge times will be fast anyway. On a L2 3.3kwh charger the PiP should be done in not much more than hour. Either way you just need to do the cost/benefit analysis for yourself. In my opinion the Volt is borderline whether you need it or not, but with the PiP running the engine anyway for heat I think it would just be a waste of money.
    https://www.homecharging.spx.com/volt/Display.aspx?id=7&menu=14
  10. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    I just wanted to clarify a bit here, even though you might know this, others might not. It is not necessary to install thicker gauge simply to accommodate the higher voltage. The thicker wire is for higher amps.
    Even with regular gauge wire, it would still be possible to use a 240V EVSE, but at the lower amp setting. (such as Ingineer's modified EVSE)
  11. bisco
    52,391
    but code requires 12 gauge for a 20 amp breaker. otherwise, someone might pull more amperage and melt the wire before the breaker blows.
  12. Roadburner440
    316
    59
    Hampton, VA
    Using regular gauge wire is a bad idea, and it is not recommended by any of the EVSE manufacturers. I am pretty sure things like that are what are responsable for these home fires involved electric cars. Either people using incorrect gauge or wire, or using alumnimum wire and then drawing to much current across it.... The first sheet of paper in the box for my Voltec EVSE was a warning stating that I must use 12 gauge wire, and a 20 amp circuit breaker. I went with 10 mainly because after my experience with the portable charge cord heating up I wanted to make sure that I had big enough wires to safely handle 240V@15 amp for 4 hours.
    As stated by bisco even if your car does not use the max amperage the EVSE can pull there is a risk of it tripping the smaller breaker. This comes up a lot over in the Volt forums because the Volt is incapable of even drawing half of what some of these EVSE's offer.. So some people in an attempt to save money will try to put it on a smaller breaker and wire than recommended. The equipment wasn't made for that, or tested. Not to mention if you ever do decide to get an upgraded Leaf, Focus EV, or some of these other EV's that can charge at 6.6kwh then you would need to go back and pay to completely redo the wiring you already paid to have done. So if you guys buy a good EVSE I recommend just doing it right the first time. Isn't worth burning down your house, ruining your main box, or damaging your car to save $100 on materials for the install cost.
  13. crewdog
    493
    388
    Woodstock, GA
    It's just nice to know that there's an option to go to 240v if my PiP driving habits warrant it.
    A good outcome of this exercise has been that a certified electrician has looked at the panel in house. If we did opt for a 240v evse, then we'd have to disconnect the breaker for the dryer. no problem since we use a gas dryer.
    In any case, the 15a 120v gfi outlet on separate circuit is now ready to be utilized.
    Now, where might that vehicle be?
  14. crewdog
    493
    388
    Woodstock, GA
    Very good and prudent idea; if we do go with 240v evse, then will just get 10 gauge wire in addition to 12 run for 120v outlet
  15. Roadburner440
    316
    59
    Hampton, VA
    That would be a good thing! Depending on the EVSE you could possibly use the old wiring, and just remove the plug for the dryer and have it installed if it is already in the garage.. Now if you get one of those really nice units that puts out 240V@40/50/60A I would put in new wiring. I wound up using an old circuit for a hot tub that is no longer in the back yard. It was on a 50A breaker that I removed and reinstalled with a 20A. We have an electric dryer so taking that circuit would have been a no go. Depends on your driving habits like you say though. I think the PiP will be more than adequate the way it is designed to operate. For those that wish to use it an EV the most they can though will need 240V.
