Wiring route information needed
Discussion in 'Knowledge Base Articles Discussion' started by mehrenst, Feb 13, 2006.
  1. mehrenst
    mehrenst Member
    439
    San Jose, CA
    I've added a SatNav to my collection of toys for my Prius (didn't get one in the package) and now I want to add the external antenna because receiption is spotty on occasion.
    The SatNav is a Magellan so the GPS antenna is fairly small and low profile. I am thinking of putting it in the free space between the hatchback door and the door frame. The hatchback door at that point is plastic and if it doesn't work out then I'll just move it to the roof in the area behind the radio antenna. At the top of the hatchback door frame between the two rubber cable boots there appears to be enough room. My question is, "Does anyone have informatoin on the cable routing path from where the two "boots" go into the body to whereever the cables emerge?"
    I'd like to be able to route the SatNav external antenna cable along this same path if its possible. :unsure:
    Thanks.
    Tom
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Y'know, I thought I'd answered this last night, but evidently it
    didn't get posted... anyway, you might do just as well to mount
    the antenna on the dash somewhere ahead of the MFD bump, because
    the windshield allows a *very* good view of the sky from there.
    My little garmin unit does just fine with the built-in antenna, not
    even quite at the optimal angle when it's sitting in its cradle
    just to the left of the MFD.
    _H*
  3. lee
    lee New Member
    62
    Rochester, NY
  4. 616fun
    616fun New Member
    Indianapolis, IN
    I just did this with a Sirius antenna and it works great.
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,363
    67
    Yokohama, JAPAN
    I agree.
    The factory GPS antenna is located in the dash between the MFD and the windshield.
    Ken@Japan
  6. mehrenst
    mehrenst Member
    439
    San Jose, CA
    That's where I have the SatNav unit and it is dropping out or has problems acquiring the Sat when its cloudy.
  7. mehrenst
    mehrenst Member
    439
    San Jose, CA
    The wire routing I'm really looking for is from the hatchback frame forward to the dash area. Since there are airbags in the overhead area I figure its not a good idea to run it there so I'm looking for a recommendation from someone that might have done something similar.
    Thanks.
  8. lee
    lee New Member
    62
    Rochester, NY
    This guide might help:
    XM Install Instructions
    You have to right click on the above link, and choose "Save Target As...", or the equivalent, depending on your browser.
