wondering how the Prius ECVT works?
Discussion in 'Gen 2 Prius Main Forum' started by Che, Jul 2, 2004.
  1. Che
    Che New Member
    44
    Raleigh, NC
  2. Ken Cooper
    Ken Cooper New Member
    339
    Heuristic mode might be a good name for it (Of or relating to a usually speculative formulation serving as a guide in the investigation or solution of a problem).
    Personally, I can see MG1 being supplied with a counter force (reversed voltage polarities on the stator) that would put a stopping force on the sun gear that would, in turn, force ALL of the internal combustion engine's shaft rotation power to be transferred via the planet carrier and planets to only the ring gear during 'ICE only' drive mode.
    But during deceleration or coast mode I can see (heuristically) MG1 in 'help charge the battery mode' resulting in both ring gear rotation (turning due to the car's momentum), and the engine's power (if the engine's running), going primarily to the sun gear (because the sun gear becomes the path of least resistance - a very light load compared to the ring gear).
    Sorry, but this old retired engineer has a real problem with virtually all of the Prius ECVT writeups found so far. They seem to have been accepted as gospel (most are several years old) but it also seems that no one has actually tried to follow them, detail by detail, and have them work out based on the laws of common physics. In reading them, you might note that whenever the logic of their explanation get's tough, they introduce the words microprocessor, microcontroller, computer, or ECU into the explanation as if these gadgets were capable of doing some kind of magic beyond the scope of their capabilities).
  3. seanwachob
    seanwachob New Member
    28
    San Jose, CA
    Still confused
    I've seen many descriptions of how the power is split between the ICE and electrical motors, but I think they're all leaving one step out. If the electric motor is starting the car with the engine off, what forces the power to go to the wheels rather than spinning the engine backwards? Is there some braking mechanism on the ICE? Similarly, what about when the ICE is supplying power and the motors are not? Does the system use electrical power to force the motor to stay in one place, fighting against the ICE? Would they really waste power like that?
  4. richard schumacher
    7,664
    1,046
    United States
    Re: Still confused
    It takes little power to do that: energy is the integral of force times distance, and if the distance is zero (that is, if the object doesn't move) then the energy is zero. Similarly, your desk uses very little power while suspending your computer monitor above the floor :_> It's not really zero in a Prius or in your muscles because those mechanisms use power to dynamically create force (moving magnetic fields, moving myosin heads, respectively), not statically like the desk does it.
  5. Ken Cooper
    339
    Re: Still confused
    Remember, when power is supplied to motor/generator (MG2) stator windings, that MG acts as a motor that drives, or helps drive the car.
    When the ICE is driving the car and when MG2 is NOT driving or helping to drive the car, the rotor on MG2 turns at the speed that the ICE powered ring gear is spinning, and, because no power is supplied during that time to MG2's stator windings, MG2's rotor spins freely with virtually no resistance to the ICE.
    Remember too that the ICE is also driving the smaller MG1's rotor (when MG1 is acting as a generator) supplying power from its stator windings to either help power MG2 or to charge the battery.
    Keep in mind too that when the ICE is off and the computer want's to turn it on, the computer tells the battery to supply power via the inverter to MG1's stators causing it to be a motor. Now the rotor on MG1 is already spinning (mechanical transfer of spin from the final drive connected ring gear via the planetary gears to the sun gear which is tied to the rotor of MG2). The power from the battery (via the inverter) simply causes that rotor to spin even faster. Then .. the difference in the speed of the fast spinniing sun gear and the slower turning ring gear has to go somewhere - so the planet carrier starts spinning to make up the difference. The planet carrier being tied directly to the ICE's drive shaft get's that shaft turning, starting the ICE (the internal combustion engine).
    Once the ICE is started, the computer takes power off MG1's stators and MG1 is reverted back to being a generator.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I believe in this case it actually causes MG1 to spin slower and/or change directions to start the engine. When MG2 is driving forward and the ICE is stopped, MG1 is spinning backward (relative to the ICE rotation and such). Simply putting some counter-force on the already spinning MG1, while momentarily increasing force on MG2 to lessen the perceived "nudge" causes the ICE to spin forward almost instantaneously. At this point, MG1 will probably be spun forward or backward(depending on whether the ICE is warming up or providing power) by the ICE, and the relative speed of each component.
    Nomiographs are most helpful to visualize this once you learn how to read them. :-D
  7. Ken Cooper
    339
    htmlspinnr, It sounds like you're pretty well convinced that it makes sense that the sun gear should be stopped or rotated in the direction it doesn't normally rotate in order to start the engine.
    I presume you visualize the planetary gear set as a ring gear linking with planet gears linking with the sun gear. And if the rotation speed of the sun gear doesn't match its ratio equivelent speed of the ring gear, the planet carrier must be spinning.
    I also presume you see the momentum of the drive on the ring gear as the force that starts the engine, relying on the sun gear being forced electrically to slow or reverse in order to assure sufficient rotation speed difference between sun and ring spin speeds in order to make the planet carrier spin at a rate sufficient to start the engine.
    That could work, just as speeding up the sun gear would work to meet the same end. Your input doesn't match with the research I've done but, then again, as I've mentioned in earlier postings, I haven't found a paper on the subject yet that suggested full understanding by any of the writers on the subject.
  8. HTMLSpinnr
    5,341
    920
    251
    I get most of my info from the NCF guide that was released almost a year ago. $10 at techinfo.toyota.com will allow you to download it if you're interested.
    Also bear in mind - rotating the sun gear faster when the car is near 42mph would case MG1 to overspin at -10000rpm (reverse) - therefore it's logical that it should reduce in speed to provide the starting torque on the ICE.
    -Rick
  9. Ken Cooper
    339
    Thank you htmlspinnr! I'll order it.
    By the way, would you please look in this Toyota resource you mention and share with us what the maximum allowed RPM is for MG1 (I'm not sure why I would be interested in knowing what the maximum reverse RPM is though, at least from the perspective of its relationship with the power split device).
    Also, does the $10 cost for this NFC Guide include the subscription fee refered to on this TIS site (see quote from its lead-in page below)?
    "Thank you for your interest in the Toyota | Lexus Technical Information System or TIS. To start your subscription, please complete the following simple, three-step process to create your own personal account. For your reference, the progress meter below will display your current status.
    Step 1: Register your User Name and Password and provide the necessary Personal Information to create your account.
    Step 2: Select your preferred subscription type and duration and also enter your billing details.
    Step 3: Your payment is processed and your account is activated and ready for use. An email will also be sent to your registered email address to confirm the transaction. "
  10. HTMLSpinnr
    5,341
    920
    251
    Yes - I'm referring to the $10/day access fee. W/ broadband and some intensive searching, you'll get the NCF, and repair manuals, as well as TSB's, etc.
    MG1's max RPM is 10,000 RPM in either direction. MG2's max RPM is 6500 RPM IIRC (poss 6000).
  11. Ken Cooper
    339
    Rather than IIRC, would you be so kind as to quote directly what the NFG guide says is the max RPM for the 2004 Prius MG1.
    Also, would appreciate it if you would also quote directly what it states about MG1, in conjunction with the power split device, on starting the 2004 Prius ICE.
    Thanks in advance,
    Ken
    P.S. insightcentral has some very good descriptions of hybrid technology. Here's what that site says about starting the Prius:
    "When power demand becomes higher, usually between 13 and 25 mph, the Prius's gasoline engine will be started. This is done by directing energy from the battery to motor/generator "G", to increase its speed. This, in turn, will cause the gasoline engine to start moving. When fuel supply and spark are turned on, the engine will then be running."
    Other sourses that I haven't yet located (but will) also say the same thing about starting the car, some in more detail.
    Sorry to sound like such a skeptic, but I've just become a bit frustrated by all the misinformation that's out there on the subject of the Prius ECVT.
    Oh by the way, there are some very sophisticated writeups written back in the early days of the Prius that even include math and nomographs. Please note though that if you use the most commonly referenced of these (even discusses the backward running MG1), at the bottom there's a very clear "no liability" statement. Just like everything else on the web, one must never take anything as gospel.
    Valiant V likes this.
  12. HTMLSpinnr
    5,341
    920
    251
    Picky picky... :-P
    From the '04 NCF (thsiicon.pdf):
    1. MG1 and MG2
    General
    • Both the MG1 (Motor Generator No. 1) and the MG2 (Motor Generator No. 2) are compact, lightweight, and highly efficient alternating current permanent magnet synchronous type.
    • Serving as the source of supplemental motive force that provides power assistance to the engine as needed, the electric motor helps the vehicle achieve excellent dynamic performance, including smooth start-offs and acceleration. When the regenerative brake is activated, MG2 converts the vehicle’s kinetic energy into electrical energy, which is then stored in the HV battery.
    • MG1 recharges the HV battery and supplies electrical power to drive MG2. In addition, by regulating the amount of electrical power generated (thus varying the generator’s rpm), MG1 effectively controls the continuously variable transmission function of the transaxle. MG1 also serves as the starter to start the engine.
    • A cooling system via water pump for the MG1 and MG2 has been added. For details, refer to cooling system (for Inverter, MG1 and MG2) on page TH-34.
      • 'Main Changes from ’03 Prius'
        • Accompanied by enhancing the rotor robustness of MG1, its rpm range for the maximum possible output has been increased from 6,500 to 10,000 rpm, therefore the charging capability has been enhanced.
        • Structure of each built-in permanent magnet inside the rotor of MG2 has been optimized by redesigning it to V shaped structure, and improvement of its power output and torque has been realized.
        • For MG2 control, a newly developed over-modulation control system has been adopted to the medium-speed range.
          • From NCF for 2001:
            While I have no quote, they show power outputs from MG2 as ending at 6,000 RPM. There is no noted change for '04. It may be listed elsewhere that this is the max speed. We have, in the past derived that 6,000 RPM was the max speed as we did some gearing calculations in other threads (feel free to search my username for top speed) which showed that the Prius top speed occurs when MG2 is at about 6,000 RPM. If I had more time to waste, erm, spare, I'd do a bit more thorough check... :)
            As for starting - they only show a nomiograph which shows that the speed is reversed (-) before starting, and then forward with forward torque applied when actually starting.
  13. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    Hey Rick,
    I've always understood you to say that the limit of the MG1 is 10,000 rpm. In your last post it says it's rpm range for maximum power output has been increased from 6500 to 10000 rpm. I don't read that to mean that MG1 would be damaged by spinning faster than that, only that it's output would be limited above that speed. Have you seen somewhere else that MG1 can be damaged by turning faster than 10000 rpm under no load? That would be the case, I believe in a neutral or deadband condition above 42 mph. I achieve this condition regularly, and have mused about the possibility of damage. Thanks for your commitment to the car and this forum.
    Ray
  14. Ken Cooper
    339
    It's moot Ray. As Rick now states, MG1 is spinning in the forward direction when starting the ICE. As he said in his last posting: "As for starting - they only show a nomiograph which shows that the speed is reversed (-) before starting, and then forward with forward torque applied when actually starting." So, as it stands, the highest RPM for the sun gear, and thus MG1, is going to be 2.6 times (planetary gear ratio) the ring gear speed when the car is at it's maximum speed.
  15. HTMLSpinnr
    5,341
    920
    251
    At speeds over 42mph, the ICE will start. It may spin under no load, but it will generally start. This is the old 6500 RPM limit though, and I think we calculated that you could take it up to 50mph or so before hitting the 10,000 RPM ceiling. Once or twice, I thought I achieved engine-off "stealth" at above 45mph, but I since haven't been able to accomplish it - even at very light pressure. This may suggest that the no-load limit is 6500 RPM and the loaded limit is 10,000 RPM (via programming). The actual limits may very well be higher, as I can almost guarantee that due to the cold "engine hang" issue, I've likely exceeded 10,000 RPM on MG1 on more than one occasion for 1-2 seconds w/o consequence.
    Also note - that there is an upward limit implied elsewhere in that Traction Control is provided on the Prius to prevent wheelspin that could suddenly stops under full power, which would cause MG1 to overspin if the ICE didn't slow down at the same instant that the wheels gained traction.
    Ken, I said that MG1 is spining backward during forward motion, and then forward torque is applied. It may not be spinning forward as it starts the ICE if it is spinning at a high rate of RPM - it only needs to reduce it's speed by (~1000rpm * the ratio between the sun and the planet gears) in order to accomplish engine start. If I were in stealth mode at 41-42mph, and MG1 is rotating at -6500rpm, it could very well only need to slow to -2500 to -3000 RPM to accomplish engine start. This slowing is caused by "forward torque", which is applied by MG1 and passed to the ICE. The end result is still that MG1 is rotating backward. Only if the ICE revs up at that speed would MG1's direction change to "forward".
    However - at a standing stop, MG1 does spin forward to start the ICE.
  16. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    I found the following link to be most helpfull when trying to unserstand the power split device.
    Grahams Prius site
    It has a few animations and is clear.
  17. HTMLSpinnr
    5,341
    920
    251
    You can check this link too:
    What's Going On
    This shows diagrams of the PSD in various states, and further discusses what's going on during each mode. Graham too asserts that MG1 could be spinning backwards and slowing and or spinning forward to start the ICE depending on the speed of the car.
  18. Ken Cooper
    339
    Rich, this is an EXCELLENT link. I sincerely wish I had found it before. It would have saved a lot of trying to figure out the errors or ambiguity in other PSD description postings I had come across. Also, I notice it postdates Graham's referenced link noted in an earlier posting (I think he hadn't quite mastered some of the details of operation when he wrote the earlier explanation).
    If you don't beat me to it, in the future when I see a question here on the operation of the power split device I'll answer simply by posting this link.
    Thanks again,
    Ken
  19. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Not the moderator; however, the answer is to check the "Delete this Post" box below the message composition window after clicking "edit".
  20. Ken Cooper
    339
    Thanks 10132003, looks like the moderator responded with his delete of my duplicate post before I got a chance to follow your advice to do it myself.
    Ken
