Won't go into ready mode - already replaced 12v battery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mores, Apr 6, 2024.
  1. mores
    mores New Member
    Delaware
    2012 Plugin-Prius
    Would not go into ready mode.
    Bought brand new 12v battery. ( previous battery was 8 years old - 11.7 volts off / 11.3 volts on )
    Charged new battery on 1amp NOCO Genius charger for about 18 hours.
    Will still not go into ready mode.
    System off:
    12.57 volts at battery terminal
    12.54 volts at fuse box
    System on:
    12.33 volts at battery terminal
    12.22 volts at fuse box
    Live voltage data provided by VEEPEAK OBDCheck BLE + Car Scanner
    11.2 - It drops to 10.7 when I press on the brake pedal.
    #1 mores, Apr 6, 2024
  2. mores
    mores New Member
    Delaware
    Car was working fine last week.
    Hear are the original codes that showed up:
    PM1 gatewayPM1 gateway
    DTCs: 1
    U0103 [0xC103]
    Data bus, gear shift module - no communication
    Status: Confirmed
    Electric window/Rear left doorElectric window/Rear left door
    DTCs: 1
    B2312 [0xA312]
    Status: Confirmed
    Entry & start / Smart keyEntry & start / Smart key
    DTCs: 5
    B2786 [0xA786]
    Ignition Switch OFF Malfunction / 99
    Status: Confirmed
    U0100 [0xC100]
    Data bus, engine control module (ECM) A - no communication
    Status: Confirmed
    U0142 [0xC142]
    Data bus, body control module (BCM) B - no communication
    Status: Confirmed
    U0155 [0xC155]
    Data bus, instrumentation control module - no communication
    Status: Confirmed
    U0293 [0xC293]
    Lost communication with hybrid powertrain control module
    Status: Confirmed
