Won't shift into gear, occasionally
Discussion in 'Gen 2 Prius Technical Discussion' started by carlbikes, May 22, 2022.
  1. carlbikes
    carlbikes Junior Member
    Gainesville, FLorida
    08 Prius with 245,000 miles. Occasionally after turning on, the car will not shift into gear, not drive, not reverse. After shutting down and restarting, everything works o.k.?????
    49,409
    check the 12 volt health with a free load test at an auto parts store. how old is it?
  3. carlbikes
    Thanks. 12v battery is less than 2 years old.
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    That's no guarantee.
    Still, I don't think it's the 12v. I sometimes had that on my 2005 Prius. It only seemed to happen if I was in a hurry. If I slowed down just a fraction, pressing deliberately on the brake pedal and on the Start button, before a kind of deliberate move of the shifter joystick, it worked every time. I'm not saying to act like the sloth in Zootopia, just slow down a little bit.
    ANDRAS RIMELY and carlbikes like this.
  5. carlbikes
    Thanks. I think that is good advice. Seems to be working.
    ANDRAS RIMELY and jerrymildred like this.
  6. tracy ing
    tracy ing Active Member
    384
    167
    wash dc
    Here is my tranny horror story, it might help someone, same issue, wouldnt go into gear, eventually we were stranded.
    I will cut the long long story short, after lots of messing around I came to the conclusion that the power train control module was bad, got one off ebay and was then told the dealer had to program it, then was told, no, turn the car on with a battery charger and leave it and it will program itself, and that worked, for a few days, then the problem returned. I went over the schematics and found that the main 12 volts for this module, which is mounted next to the engine ecu under the glove box, comes from a fuse under the hood, when i pulled that fuse it disintegrated into powder, fairfax county road salt destroyed the fuse. replaced it, no more shifting issues. car now has 300k on it still going.
  7. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Thats even a better reason to test it. If it fails, probably still under free replacement warranty unless it’s a really cheap one.
