Won't shut off and display is dark
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wiiawiwb, Dec 18, 2013.
  1. wiiawiwb
    wiiawiwb Junior Member
    47
    Hi everyone. I have a 2008 Prius, original owner. Two problems.
    1) When it gets cold (5F-15F) and I start the car, often the display showing the MPH is completely black. The whole strip. The cruise won't work either. Once the car runs for a half hour, or the outside temperature increases, then the display lights go on and the cruise control works. I don't know what is causing this.
    2) Today it was cold and the MPH display didn't work. I drove it for only a bit and when I parked in my driveway the car would not shutdown. The engine sounded like it was down, the MPH display was black BUT the center display was on and lighted. I tried holding the Power button down to have it reset but the darn thing would not fully power down. Eventually it did power down completely after trying different things. Also not sure what was going on here.
    Any help would be appreciated.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,974
    4,716
    Texas Hill Country
    Probably a new display is needed. Toyota will change it for free even out of factory warranty. No shutdown is part of the issue. They issued an extension of warranty for this part when and if needed. I keep my copy of the notice in the car. The dealer can look it up.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to the Gen II forums from the Prius v forums.
  4. wiiawiwb
    47
    Do you, by chance, have a copy of that notice you could post or a link to it?
  5. vskid3
    vskid3 Active Member
    773
    228
  6. wiiawiwb
    47
    Just found a copy of the TSB. Thanks!
  7. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    This might help you also. You have all the symptoms of a bad combo meter.
    To shut down hold the power button down for a minimum of three seconds. Some have trouble even with that, but keep holding it down until the Prius powers down completely.
    Read and print the pdf file for more info.
